J30A1 Tranny Swap Question.
Hi guys,
I've got a 97' Acura CL 3.0 - Tranny gave out, of course.
I did a little research from where people who had 98-02 accords were swapping out their trannys for CL 6SP Manuals.
I never found a reverse answer though - Could I take a transmission from a 98-02 J30A1 Honda Accord and bolt it directly into my 97' Acura Cl ?
well the tranny case codes are almost the same..
In my noob opinion I would say that 98% sure you could put the 4 speed auto from a 98-02 Accord V6 into a 1997 Acura CL.
Both of those cars use the SAME motor. The J30A1 was "transplanted" over into our 98-02 Accords. So the engine bell-housing is the same, therefore, the 98-02 4-speed auto SHOULD bolt up.
As far as the Acura ECU controlling the 98-02 Accord tranny, sensors and stuff...don't know. And having the mounts in the right place ...don't know. And the drive axles.....again, don't know.
Devine
Transmission & Drivetrain
Oct 6, 2009 06:09 PM
DAfanatic
Jan 1, 2009 08:38 PM
30, 98, acura, bolt, cl, compatible, fit, j30a1, manuel, my97, performance, tranny, transmission, transmissions, valves
