Suspension & Brakes Theory, alignment, spring rates....
best oem upgrade?
Old Aug 12, 2011 | 11:12 AM
sh!ft's Avatar
Who the fack changed my title?!
Default best oem upgrade?
ok so i just ordered a set of legend 2 piston calipers, i have my 40/40 prop. valve, i upgraded to steel braded lines all the way around, and i am now needing to make a selection for my brake booster and my master cylinder. i have a 13/16ths cylinder, but im not sure i wanna use that. which should i use? and which brake booster should i use? the platform is an ef hatch back 1990. i want the best braking that an OEM booster and a master cylinder will give me. any suggestions?
Old Aug 12, 2011 | 07:20 PM
rallypoint_1's Avatar
Default Re: best oem upgrade?
You can always use a 15/16 MC and booster from a non-abs DA. You can even keep your booster and use a the 15/16 MC from a Civic EX sedan. The EX MC will fit on your booster. If you go the DA route then you need both. No need to re-route brake lines on either option. Btw...I did the DA thing and swapped both.
Old Aug 12, 2011 | 07:22 PM
sh!ft's Avatar
so if i use the da setup with a 15/16ths i can still keep my original lines? dont wanna have to go through all that **** of rearranging them.
Old Aug 12, 2011 | 07:23 PM
Yup. You keep your original lines!! Kind of cool huh!!
Mar 25, 2012 06:59 AM
J(ef)F
Oct 5, 2010 03:05 PM
em1pusha99
11
Jul 21, 2009 06:27 PM
gaskleppie
Nov 4, 2002 05:26 PM
