Mugen vs spoon calipers
Old Oct 3, 2002 | 08:31 AM
done's Avatar
Default Mugen vs spoon calipers
compare these to the spoon capilers
are the mugen ones 2 pot??
Reid's Avatar
Global Moderator
Default Re: Mugen vs spoon calipers (Jordo)
Mugen calipers are S2000 brakes with mounting hardware to make it a bolt-on affair for the DC2.
Old Oct 3, 2002 | 08:32 AM
done's Avatar
Default Re: Mugen vs spoon calipers (Reid)
how do mugen calipers compare to stock front ones?
Old Oct 3, 2002 | 08:34 AM
Reid's Avatar
Global Moderator
There is really no need for upgraded brakes on a DC2 ITR if you find no fault with the stockers.
If it ain't broke...
Old Oct 3, 2002 | 08:35 AM
done's Avatar
very true, i just wanted to compare it with spoon calipers, saying they are same price range..
Mario's Avatar
Single piston sliding.
Old Oct 3, 2002 | 08:48 AM
Hukd Up's Avatar
Default Re: Mugen vs spoon calipers (Mario)
so which stop better?
Old Oct 3, 2002 | 08:53 AM
Reid's Avatar
Global Moderator
Default Re: Mugen vs spoon calipers (out_a_bounz)
Both the Spoon and Mugen brake solutions seem to be angled more toward offering better pedal feel and resistance to fading than increased braking performance.
Old Oct 3, 2002 | 08:56 AM
TsunamiZC's Avatar
true..cause neither brake systems increase pad size ..or rotor size ...simply fade resistance , and pedal feel ...
Old Oct 3, 2002 | 08:59 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Mugen vs spoon calipers (tsunami_zc)
Mugen calipers use bigger rotors and require 16" wheel. Calipers are cast iron painted gold --- very heavy.
Spoon calipers are aluminum. Half the weight of the stock DC2R brakes. 4-piston.
IMO forget about the Mugen brakes.....
Old Oct 3, 2002 | 09:28 AM
EPGONZALEZ's Avatar
Default Re: Mugen vs spoon calipers (Wai)
for the price of a set of calipers from spoon
you get a more complete package from mugen
i have tried both setups and the spoon with porterfields pads did not impress me...
although it bit very hard...after about 9 laps of super hard braking....the heat took over..and all the clamping in the world wont do you any good...
maybe with some of the heat issues adressed the spoon could surpass the mugen
i have never expirienced any of the same problems with the mugens...and i i think they grab incredibly hard
my only complaint would be the price of replacement rotors,
but i think they are the most important part of this kit...
but dont take my word for it...
Robbie Montinola (drives a formula dodge and a type R) was so impressed he is considering the setup for his race car
but then again..i am mugen biased!
Old Oct 3, 2002 | 09:30 AM
IGGY's Avatar
I think there was a post like this a little while back.
Mugen is the complete system, where as Spoon is just the calipers.
Old Oct 3, 2002 | 09:40 AM
Big Phat R's Avatar
imo the mugen system should be better because it utilizes a bigger and thicker rotor.
the spoon system is lighter (doesn't help braking much), uses the OEM pad size and OEM rotor size. it may be able to clamp harder - but it won't make up for the difference you get with a bigger rotor (think: long wrench vs short wrench - increase grip pressure doesn't necessarily make it easier to turn a nut - what you need is LEVERAGE)
the only way to increase braking performance (i'm not talking modulation here) - is to increase the swept area of the rotor (by increasing radius), increase heat sink (by utilizing a bigger rotor mass), improve rotor cooling, use pads with higher Mu compounds, better fluid and better tires.
the stock system can cause the ABS to kick in with stock (street) tires - increasing clamping force does nothing but make the ABS kick in earlier. You need to make a concomitant change in tire compound or tire width to improve the braking adhesion of the tires.
Old Oct 3, 2002 | 09:47 AM
Mario's Avatar
Default Re: Mugen vs spoon calipers (EPGONZALEZ)
I think i'll be using the STOPTECH AeroRotors on my Spoon calipers pretty soon. We'll see how that turns out.
Old Oct 3, 2002 | 09:53 AM
JeffS's Avatar
Compared to a Fastbrakes Wilwood set, they're both overpriced.
Old Oct 3, 2002 | 09:55 AM
done's Avatar
Default Re: Mugen vs spoon calipers (JeffS)
any link on the wilwood kit?
Reid's Avatar
Global Moderator
JDM bling isn't cheap.
Old Oct 3, 2002 | 09:56 AM
Reid's Avatar
Global Moderator
FASTBRAKES
Brian Hasty (owner of Fastbrakes) is a great guy to do business with.
Old Oct 3, 2002 | 09:59 AM
done's Avatar
the fast brakes are much cheaper... which kit is good? the 11.75 4 piston kit?
Old Oct 3, 2002 | 10:00 AM
Wai's Avatar
Wai
Default Re: Mugen vs spoon calipers (Big Phat R)
That's a very important point. It also explains why Spoon made a kit for 15" wheels because most race tires for the DC2R are in 15" size.
If you were gonna track the car with 16" street tires and track pads, there would be plenty of lockup even with stock calipers.
Old Oct 3, 2002 | 10:08 AM
Mario's Avatar
Unfortunately, running certain 15" wheels wouldn't really match well with the Spoon calipers.
+8mm spacers = wider is better?
Old Oct 3, 2002 | 10:32 AM
Big Phat R's Avatar
huh?
Old Oct 3, 2002 | 10:48 AM
Tommy_Gunns's Avatar
If you want better stopping, upgrade your brake pads. Cheaper and very effective.
Old Oct 3, 2002 | 10:49 AM
Reid's Avatar
Global Moderator
Default Re: Mugen vs spoon calipers (Tommy_Gunns)
Don't forget a good brake fluid also.
Old Oct 3, 2002 | 11:45 AM
Wai's Avatar
Wai
huh?
That was referring to the Mugen brake system. The car would need 16" rims and choices on R tires would be very limited (only Hoosier I believe?).
In other words, Mugen system + good pads --> 16" rims --> street tires --> easy wheel lockup.
