Maint. Required light at 6k?
Old Oct 3, 2002 | 08:09 AM
Rdriven's Avatar
Default Maint. Required light at 6k?
Does the maint required flash at every 6k? Is this Hondas replacement for the color changing square at the bottom of gauge cluster?
[Modified by Rdriven, 12:10 PM 10/3/2002]
Old Oct 3, 2002 | 08:10 AM
Nate B's Avatar
Default Re: Maint. Required light at 6k? (Rdriven)
around that many miles...I thought it was about 7500 but not too sure. Just reach under the steering column and turn that biotch off
Old Oct 3, 2002 | 08:12 AM
BlueR's Avatar
Default Re: Maint. Required light at 6k? (TypeR#1111)
it starts flashing b4 7500 miles...
once you get to 7500 miles it will stay on constantly
to reset it...theres a little squarish button right underneath the dash
Old Oct 3, 2002 | 08:13 AM
skafia's Avatar
25 Year Member
Yes, the color changing squares found on all hondas, this is the same thing basically.
You can either take it to the Acura dealership and get charged $60 an hour for a guy to turn it off, or you can do it yourself. There's a button way underneath the steering column, holding it in will cause the light to stay on for a second, then it will go away.
Just be warned though, doing it this way will knock off 5,000 miles off the life of your motor every time.
[Modified by skafia, 9:13 AM 10/3/2002]
[Modified by skafia, 9:26 AM 10/3/2002]
Old Oct 3, 2002 | 08:15 AM
Reid's Avatar
Global Moderator
Default Re: Maint. Required light at 6k? (skafia)
Please don't purposely feed people bad information.
Old Oct 3, 2002 | 08:16 AM
hungsteR's Avatar
Default Re: Maint. Required light at 6k? (Reid)
Yeah, some people actually believe everything that is typed in here.
Old Oct 3, 2002 | 08:17 AM
(__________)'s Avatar
I just had my light come on around 73K and I hit the button to turn it off
[Modified by steves98itr247, 12:18 PM 10/3/2002]
Old Oct 3, 2002 | 08:19 AM
skafia's Avatar
25 Year Member
Default Re: Maint. Required light at 6k? (steves98itr247)
oh great, look what I started ;(
But come on guys, please don't be afraid to lighten up and use your sense of humor. We can't baby everybody on this board, if I had to be restricted to only give "sensible, righteous" information, hell, I might as well change my name to Reid2.
Old Oct 3, 2002 | 08:22 AM
Reid's Avatar
Global Moderator
There's nothing wrong with having a sense of humor, it's what makes this place more entertaining.
There was nothing in your post to indicate that it was in jest.
Old Oct 3, 2002 | 08:23 AM
yoshi234's Avatar
I shoot brides
just press the button every time j00 change da oil
yshi - who just mentioned yesterday that this hasn't been posted in a while
Old Oct 3, 2002 | 08:25 AM
Nate B's Avatar
Default Re: Maint. Required light at 6k? (yoshi234)
LOL...was that diagram created with paintshop?
Old Oct 3, 2002 | 08:27 AM
skafia's Avatar
25 Year Member
Boy I would love to meet you one day Reid.
Old Oct 3, 2002 | 08:32 AM
Rdriven's Avatar
I turned it off with the reset button as soon as it came on, I remembered where it was from my brothers R, but I don't remember his light ever coming on...I just started my car and it didn't come back on, The dealership changed my oil at about 5600 maybe they didnt reset it...does every think this is normal.
Old Oct 3, 2002 | 08:35 AM
Reid's Avatar
Global Moderator
The Maintenance Required light is just a light to scare people into bringing their car into the dealership for work.
The Check Engine light will be the light to watch for should anything ever go wrong with your car.
skafia's Avatar
25 Year Member
The maintenance required light is just used as a remind for you that you should maybe check your petro, brake fluid, coolant level, and maybe refill your window washer fluid. Stuff that an R owner SHOULD already do on a regular basis! Don't worry about it bro, worry when the "CHECK ENGINE" light comes on
Old Oct 3, 2002 | 08:58 AM
Rdriven's Avatar
thanks everyone...
Old Oct 3, 2002 | 08:59 AM
TsunamiZC's Avatar
its a blue button...you cant miss it
Old Oct 3, 2002 | 09:01 AM
benmasters's Avatar
Default Re: Maint. Required light at 6k? (tsunami_zc)
Sorry to be dumb but where is the light? will I have one on a JDM 96 DC2?
Old Oct 3, 2002 | 09:06 AM
Reid's Avatar
Global Moderator
Default Re: Maint. Required light at 6k? (benmasters)
You won't have one on your car.
Old Oct 3, 2002 | 10:31 AM
d8168055's Avatar
the h-t classic diagram...
Old Oct 3, 2002 | 10:38 AM
BlueR's Avatar
Default Re: Maint. Required light at 6k? (d8168055)
the classic yoshi diagram
Old Oct 3, 2002 | 11:54 AM
B2FiNiTY's Avatar
That's what I was thinking.
Old Oct 3, 2002 | 12:20 PM
Hooch'n's Avatar
Default Re: Maint. Required light at 6k? (ExOdy)
no problem...........
Old Oct 3, 2002 | 12:24 PM
JoshRambo's Avatar
Default Re: Maint. Required light at 6k? (Hooch at 8400-RPM)
my light first flashed at like 7k and has never gone off agian. just about to break 16k.
Old Oct 3, 2002 | 02:07 PM
B2FiNiTY's Avatar
Default Re: Maint. Required light at 6k? (Gravity)
Odd...it should go off when you hit 15k.
