PA gsr coupe
6000 obo- i can work something out with the seats if you don't want them- i know what they are worth.
car is located in south central pa
ALL WORK was done by Shaun Budgett, so you know it's done right.
i will get more picture when i can get home
7175523555- best to text
1998 honda civic coupe ex
other than some dings the body is clean. No rust.
b18c1 gsr swap with 70-80K-professionally done --able to get dyno tuned if wanted
10/10 new si seats
CAI
S2 intake manifold
Oem civic si mounts
Obx header
New stage 2 clutch
Type r cams
new water pump
new timing belt
new oil pump
new starter
new front axles
Has a/c which works
No power steering- if you can't steer this you should be in the gym and not complaining about the steering- lines are connected. need pump and bracket.
Lowered on coilovers with S2 springs
New oem flywheel
New windshield
Inspected
Aligned
Si rims with good tires
New headlights
integra rear disc conversion
new rear rotors
new rear pads
new rear bushings
new front rotors
new front wheel bearings
new front pads
new interior carpet with dyno mat
bad-
Had some hail damage. have good condition white hood and trunk
Couple dings in front fender
Passenger door was replaced when I got it
Rear quarter was sprayed.
body has 193,000 on it but it clean. all rear assembly was replaced. as you can see, basically the shell has the miles. everything else is new or has 78-80k on it.
this picture doesn't show rear discs
10/10 new si seats
CAI
S2 intake manifold
Oem civic si mounts
Obx header
New stage 2 clutch
Type r cams
new water pump
new timing belt
new oil pump
new starter
new front axles
Has a/c which works
New oem flywheel
New windshield
Inspected
Aligned
New headlights
new rear rotors
new rear pads
new rear bushings
new front rotors
new front pads
bad-
HondaMPower
Dec 5, 2003 10:39 PM
