Need alittle help from the experts. Dumping gas, backfiring
Old Aug 10, 2011 | 01:15 PM
jangocast's Avatar
Default Need alittle help from the experts. Dumping gas, backfiring
Been searching around looking at different topics, trying to find any answers to my dillema.
1990 CRX Si. OB0 PR4 ECU non chipped stock, LS B18a1 swap.
Been running good now for 3 months, no starting/running issues besides a slight hesistation when cold. Just did a narrow style header on it a week ago, no issues after completion. Yesterday on the way home from work, downshifted, car backfires and has no power...will not restart. Long story short swapped a different distributor on that puts the car into limp mode(reason why I changed it out) to get it home.
Found out the rotor screw came out and was just spinning..sweet easy fix. Put new rotor and cap on the dizzy, now car idles very low 300 rpms maybe...dumping gas, backfiring. Got a new distributor no change. Plugs were fouled from gas, cleaned them, no change.
Car has had a code 14 for IACV since I got it, just idled low. Now throwing codes 1-o2, 5-map, 43-fuel supply, in addition to 14. Checked 02 sensor, no problems found, disconnected plug, no change.
Disconnect MAP sensor, idle jumps to 800 rpms but is still burning to much gas and backfiring.
I need some ideas here before I keep throwing parts at it..would appreciate any help.
Thanks guys
Old Aug 10, 2011 | 01:31 PM
jangocast's Avatar
Default Re: Need alittle help from the experts. Dumping gas, backfiring
forgot to mention, when I do put the bad dizzy on that puts it into limp mode, car runs fine with no hesitation, just wont rev over 3500 rpms..I'm stumped.
NoItsNotHerEk9
Apr 20, 2011 05:36 PM
racingcrx
31
Nov 7, 2010 06:59 PM
415Hatch
Aug 29, 2010 08:30 AM
vegas hoe
14
Nov 3, 2009 10:03 PM
omniracer23
May 14, 2002 01:51 PM
