Suspension & Brakes Theory, alignment, spring rates....
1992 Hatch suspension question
Old Aug 9, 2011 | 10:20 AM
Cloud7659's Avatar
Default 1992 Hatch suspension question
Hello all,
I recently bought a 1992 hatchback civic. I've since changed the oil, replaced the exhaust (too loud for my taste) and washed it.
Anyways, what I noticed about the car is, it tends to bounce really hard on bumps and ride really harsh. I know absolutely zilch about suspension, and was wondering where I should start and what I should replace to make the car ride more comfortably.
Note: I like the "low" car look, but don't care about it enough to sacrifice ride comfort for it.
Old Aug 9, 2011 | 01:20 PM
90_EX_Civic's Avatar
Default Re: 1992 Hatch suspension question
what is on the car now?
Old Aug 9, 2011 | 01:23 PM
Libertariat's Avatar
Ek Forever y0!
This.
Also, what are you using the car for? Budget? Height goal?
I'm on progress CS-II 350lbs/350lbs. They cost $600, and i've been very happy with them daily driving and occasional track duty:
Sitting still I'm about 1 finger gap in front and rear. Maybe tucking a little tire in the front.
Old Aug 10, 2011 | 05:57 AM
Cloud7659's Avatar
I think the stock suspension is what's on, but I'd have to check to be sure. I use it as a daily driver/transportation. Sometimes highway, sometimes stop and go. My goal is just to not have a ride that's as bumpy as it is.
Old Aug 10, 2011 | 06:45 AM
Ek Forever y0!
If it's stock suspension then you've got some serious damage to the suspension components if the ride is harsh. Are you sure it's not lowered?
A good, cheap setup would be some Koni Srt shocks and a tein or H&R with a soft rate. ~300front 150-200 rear.
Originally Posted by vTeC_aLL_daY77
BUMPPPPPPPPPPP
Why on God's green earth did you bump this?
Old Aug 10, 2011 | 07:07 PM
get a set of koni sports and find some used type r springs. if it's not low enough for you, the spring perch's on the sports are adjustable.
Old Aug 18, 2011 | 09:07 AM
<MeanDelSol>'s Avatar
Function & Form type II's
Best money spent, great coilover
Old Aug 18, 2011 | 03:38 PM
grumblemarc's Avatar
The Grumpiest
If you say so.
Old Aug 18, 2011 | 03:43 PM
Katastrophic's Avatar
What you have is what happened to me, Over years/miles of use my struts went to crud and rode terribly, everyone told me they were probably "blown" (blanket statement), so i called honda and ordered some new struts and installed them the next week. Boy the ride difference between 188k mile struts and brand new struts is HUGE.
IN SHORT GET NEW STRUTS if you don't want to buy aftermarket.
if you go aftermarket then buy what the other posters have suggested.
Old Aug 18, 2011 | 09:09 PM
98civdx's Avatar
Master Detailer
You do understand you could have bought Koni/gc for LESS and have a BETTER
setup?
But oh well, I guess becuase they aren't 1 peices they suck.
Old Aug 18, 2011 | 09:22 PM
setup?
Old Aug 19, 2011 | 03:34 AM
Ek Forever y0!
setup?
Like I mention in my suspension choice writeup in my sig. There really aren't enough reasons to justify buying anything else than what I listed.
Old Aug 24, 2011 | 01:57 AM
kStatus's Avatar
Originally Posted by Libertariat
This.
Can't wait to get my set of PROGRESS CS-II 350/350. Been reading a lot of your post's and i can't wait to install it.
Old Aug 24, 2011 | 05:29 AM
Ek Forever y0!
It's a great daily driving and entry level autocross coil over. If you're a quick learned you'll quickly outgrow the setup and need something a bit more aggressive for heavy autocross use. Seat time is still infinitely more important than a new suspension for me, but I look forward to upgrading next season after I get my engine swap done this winter.
Old Aug 26, 2011 | 09:18 PM
Burton42's Avatar
What are you switching to, the koni/gc set up?
Old Aug 27, 2011 | 04:13 AM
The Grumpiest
Need stiffer spring rates.
Old Aug 27, 2011 | 08:38 PM
Ek Forever y0!
Once I get my swap done this winter, and paint in the spring, I'll be going with AMR for next years autocross season.
550F/450R and a 24mm rear sway bar most likely. Currently using a 22mm.
Old Aug 28, 2011 | 03:58 PM
Burton42's Avatar
At the risk of going off topic, what engine swap are you doing, and what are you running now? Also, are you selling your current setup when you do your swap?
Old Aug 28, 2011 | 04:16 PM
The Grumpiest
Instead of GOING off topic why do you not just ask him via a PM?
Old Aug 29, 2011 | 02:34 AM
Burton42's Avatar
my bad
tjdmcoupe
Dec 7, 2011 07:55 PM
Mr. KDes
14
Jul 1, 2009 11:49 AM
Donutyea
Honda Civic (2001 - 2005)
Feb 12, 2009 04:55 PM
dc2teg2006
13
Oct 27, 2007 03:56 PM
ziggen243
Suspension & Brakes
Sep 15, 2005 04:37 PM
