Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
clutch squeal
Old Aug 8, 2011 | 07:31 PM
D-Rey's Avatar
Icon2 clutch squeal
Does anyone know why when I step on my clutch pedal....there is a knock and squeal noise? I don't feel any slippage as its wearing....but its the damnest noise? HELPPPPP
Old Aug 8, 2011 | 09:30 PM
brian1037's Avatar
Default Re: clutch squeal
Bet it ain't as bad as mine.
http://www.youtube.com/watch?v=ZbP2N3f_8YI
Old Aug 8, 2011 | 11:06 PM
It Wasn't Me's Avatar
Search + "clutch" = https://honda-tech.com/forums/honda-civic-2001-2005-78/squeaky-clutch-2963479/
Old Aug 13, 2011 | 03:13 PM
D-Rey's Avatar
Icon2 Re: clutch squeal
geez man...yours is way worse...what is the problem and have you found a fix??? thanx for the reply.
Old Aug 15, 2011 | 06:16 AM
j.bro's Avatar
The groan is usually from lack of lubrication on the clutch fork pivot or where the slave cylinder contacts the clutch fork. You can lube the clutch fork easily by pulling back the boot and adding grease, and you have to use a mirror and a long/thin paint brush to get at the pivot. I've had temporary success with each method ha ha.
Old Aug 17, 2011 | 05:38 PM
D-Rey's Avatar
Icon3 Re: clutch squeal
You were so right man...just a little lube and maintenance is what i needed! I very much appreciate your time and assistance in understanding the problem...I try to learn as much as i can from others.
Old Aug 17, 2011 | 06:09 PM
daniyar's Avatar
i have tyhe same problem. i think better put grease on it))))
Old Aug 17, 2011 | 10:42 PM
That sounds familiar..
It's more than likely the joint where the slave cylinder meets the release fork.
You'll need to pry the rubber boot back (away from the housing, towards the slave cylinder) and lube the joint.
I used white lithium grease on mine. Haven't had the noise return in some time now.
Oh, that's why.
Seriously, though, the noise used to drive me nuts! It hasn't returned in at least two years. :knockonwood:
Old Aug 18, 2011 | 04:11 PM
TOO MUCH TORQUE's Avatar
be prepared to bleed the clutch lines
http://www.team-integra.net/forum/19...now-guide.html
but this will fix your problem.....fixed my squeal and bird chirping noise. i used anti seize and it works fantastic.
Old Aug 19, 2011 | 03:21 AM
daniyar's Avatar
thank you for informations. i thought it is just the pedal .... i will do maintenance of clutch.
Old Aug 25, 2011 | 08:39 PM
Brian swetzle's Avatar
I have the same issue and it's been driving me crazy, I do have the noise and sometimes I smell something like burning. the other thing is I have a very loud sound coming from the front wheel and gets louder if go faster , I think it's the front bearing. I'm not sure if these symptoms are related or no . any help ??
Is there any video or that shows how to do the lubrication thing please help
Old Aug 29, 2011 | 10:12 AM
TheAmorousPanda's Avatar
I had that a little bit. I might want to try that....
bbrian
Transmission & Drivetrain
Jun 14, 2013 10:09 AM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
megaman096
Nov 8, 2004 11:26 AM
jdmcivicferio
Jul 9, 2004 02:15 PM
H22Apexi
Jun 5, 2003 01:04 PM
