building a mini me and have a few questions
Old Aug 8, 2011 | 06:50 PM
290allen's Avatar
Icon6 building a mini me and have a few questions
ok so i have done alot of reading on various forums and read a few different write ups but there is alot of conflicting info and that being said please only post if you have first hand knowledge of this build.
this is going in a stock 89 civic wagon. i will be doing a mpfi conversion which i have done before,
im using a d16a6 bottom end and a d16y8 head along with a d16y8 intake mani, it will be converted to obd1 via a rywire kit and running on a p28.
my question is what distributor do i need for this set up?
thanks for your input
Old Aug 8, 2011 | 08:00 PM
KINGVEM^^ED6's Avatar
Default Re: building a mini me and have a few questions
O B D 1 VTEC dizzy
if your running a p28 bruh
Old Aug 8, 2011 | 08:15 PM
290allen's Avatar
i read somewhere that it wont mont easily with a d16y8. any info on that?
or is it the same bolt pattern?
Old Aug 8, 2011 | 08:21 PM
turbostd's Avatar
obd1 non vtec is what you need. There is no such thing as a vtec dizzy just different bolt patterns. The ob1 vtec dizzys wont bolt to your head. You could also use a obd2 d series dizzy if you change the plugs on it to obd1.
Old Aug 8, 2011 | 08:38 PM
290allen's Avatar
thank you so much, i have the d16y8 dizzy that came with it, i was just unsure of it. alot of people think that the obd2 dizzy send signals differently.
also have you personally run it this way or know first hand of someone who did. thanks again
Old Aug 8, 2011 | 09:02 PM
turbostd's Avatar
I am running a y7 dizzy on a y7 in a 94 vx using a p06 ecu.
Old Aug 9, 2011 | 12:01 AM
DCRB's Avatar
.... guys seriously? o/p you run the y8 distributor. obd1 and obd2 are compatible, you will simply need the obd2 dizzy plug and you're set. don't rig something up that sets yourself up for failure. do it right the first time
Old Aug 9, 2011 | 04:21 AM
290allen's Avatar
Icon7 Re: building a mini me and have a few questions
thanks again just needed confrimation on this, i already have a y8 dizzy and swapping plugs wont be any issue. thanks for the info
,Philip
Old Aug 9, 2011 | 07:48 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Just to confir... I just did this on an old friends vehicle and it works fine. Complete D16Y8 engine (distributor too) running off a P28 ECU.
Old Aug 9, 2011 | 03:05 PM
290allen's Avatar
cool, thanks for the confirmation,
and thanks to all who responded.
madmike84
13
Jul 11, 2009 07:44 AM
GsR92HaTcH
Jul 26, 2007 02:14 PM
91lsteg
Jul 20, 2007 07:21 PM
slopoke1989
Apr 30, 2007 06:13 PM
Concept Tuning
Mar 16, 2006 01:47 PM
