96 Accord Overheating Issue
I have a 96 Honda Accord 4cyl. For several months now my cars temperature keeps rising up despite several repairs. So far the things that have been done are as follows: New radiator, the hoses were changed, a mechanic removed the heating system since I live in Miami, just recently one of the main hoses exploded so it was replaced, the circulating system as check for air pockets. Each and every time after repairing the car always seems to start heating up again and the only thing keeping the temp low is when its in motion and the air runs through the engine and the fan turns on after the car has been turned off. What can I do these repairs are starting to come out costly and I am getting really annoyed since each repair last like two weeks before it starts heating up again . HELP PLEASE !!!!!
Agree with checking the coolant level......take it in., something is replaced and the coolant topped off....two weeks later the issue comes back. IMO-there is a leak somewhere....internal or external but it really sounds like a loss of coolant.
to a bigger problem.The only thing that wasn't touched is the thermostat.I don't remember on this model if you could install the thermostat incorrectly(happened to me once).If the thermostat is ok and the proper rating I would do a cylinder leak down test.Before going to big stuff do a pressure test of the system and see if pressure drops or not.
I have the same problem , im starting to wonder if its the head gasket as well , i replaced thermostat main hoses radiator did a waterpump timing belt replacement corrected the timing, and it would still end up over heating i think its the headgasket.
My overheating Accord is a 95, but can't imaging the 95 and 96 are tremendously different.
I puled the green cap at the thermostat as suggested and when I hook it up to my multi-meter, I get nearly 12VDC across the connection, but the drivers side fan does NOT turn on. Seems that most replies were related to a functioning drivers side fan when bridged.
I allowed the engine to warm up until the gauge passed the normal midpoint, about 3/4 of the way to red, then checked the plug the green cap attached to, checking ohms resistance. I expected to see a reading of zero, but saw a 1 instead.
Does this mean the drivers side fan is bad and needs replaced? The resistance across the thermostat plug would seem to me to indicate that it's faulty too?
By the way, I pulled out my ramps and put it on them to do the burp thing too.
Thanks in advance,
Shawn from AZ
"Sure it's a dry heat...but then so is fire!"
Thanks in advance,
Shawn from AZ
Hello jefferds
I'm battleling the same issue with the Honda accord LX.
I have the Headgasket replaced, and had the Water pump, put in a Honda Accord Thermostat, replaced the 4 Sensors One on the TS housing, One on the Upper house towards the Engine, two below the Distributor cap... Checked the relays, and the fuses, replaced the Radiator and the The passenger fan... It over heats...so check the specs on the sensors they are suppose to come on at a temp of 102to 105 C so they are doing that...
Boths fans when the AC is on should be running... even the fan come on when the car is off but the Niddle is still 3/4 to almost to the max up..I do not think that is normal... so something in the system send that temp out of wack and I'm not sure what else to check.
Any ideas that would help I welcome it.
Thank you,
Andrew
Thank you,
Andrew
Hello jefferds
Thank you,
Andrew
Thank you,
Andrew
The fan switch in the front of the engine nearest to the radiator really isn't even needed. It rarely does anything. It's only working in your instance because the car is overheating because the other sensor isn't doing its job.
Thanks in advance,
Shawn from AZ
Thanks in advance,
Shawn from AZ
Anyway, jump the wires together (lower hose, NOT the upper-t-stat), turn the key on, BOTH fans should come on?
On my 95 I did the key on, jumping the two wires with my multi-meter, I see nearly 12VDC, but the fan does NOT come on so I assume this means it's dead. Seems that just pulling the entire radiator is as easy as trying to remove the fan from the installed radiator.
As stated before, I let the car get warm and check across the thermostat switch and still see resistance, versus the no resistance I was expecting to see, so believe it's dead too. Anyone care to confirm one or both suspicions?
If your fan doesnt come on while the car is running and only comes on after you shut the car off most likely your t-stat is not working properly. It could be stuck closed or it could have a big *** air bubble in front of it not letting it open
Thank you for the reply.... after several attempts it goes to show you that even thought you buy brand new parts they are not necessary that they will be working. It does not matter where you buy them.
I replaced the colling fan... and the new part it came from RockAuto... that went out two months in to operation... then in the myst of trying to see what else can make the car overheat... i replace the Temp sending unit too... well that was bad. Rock auto replaced the Fan since it was under warranty and that worked but then ended up findind out that the temp sending unit from NAPA was bad brrand new part so put in the old sending unit that out took out earlier in the week and all is working normal.
If someone would ask me me the cause... not sure what part fail... but i replaced all the temp sensors except the Sending unit the radior the Honda Thermostat the water pump and the Headgasket...This foreign made car are so electronically control that one thing can through off the system I think.
I hope this would help someone else.
thank you.
thank you.
The first thing to do is always jumper 12 volts to the fan in question. If it runs then look elsewhere. It seems a lot of bad parts new out of the box is too common now. It took me much longer to fix my fan problem because of a bad out of the box fan relay. You can find electrical drawings on line by Googling your car.
how exactly do you safely and properly jump the fans together? I am having issues with the larger fan on the passenger side not coming on. I'd like to test it before I go on to other parts to see if that is what is causing my overheating while idle or low speed issue
(94 non vtec 4 cyl)
(94 non vtec 4 cyl)
i am having many of the same symptoms above and have concluded that it is the head gasket my question is...should i just do the head or should i do an engine swap???looking for the cheapest route...also need timing belt, water pump, and clutch...my poor car
(94 non vtec 4 cyl)
(94 non vtec 4 cyl)
well the biggest reason id that when i tried to burp the system...the air never stops coming...several people have told me that the only way air gets to your cooling system is from the combustion chamber...i am taking it tomorrow to get a leakdown test...as far as i can see there is no water in oil and no oil in coolant...the car runs and drives it just overheats about 1 mile after driving...the last time i drove it i pulled over and let it cool for a few min...i could only go 1-2 miles before it got close to to red again...needless to say my 12 mile trip took over an hour...i dont want to make thing worse and i definately dont want to be stranded...also there is no heat in the car and i know that could also be related...hot water not making it to the heater core due to exhaust in the cooling system...i could be wrong cuz this is all new to me....anyone got any ideas...would a bad water pump or hose allow air into the sytem???
A leakdown test shows if there is leakage in the cooling system. There is a tester that can be attached to the radiator cap opening that will tell you if there are combustion particles in the coolant. Sounds to me like you have a stuck thermostat if you cannot go one mile. Combustion geeting into the coolant will not over heat the car that quick.
