Car won't start up, PLEASE HELP!!!!!
Old Oct 3, 2002 | 04:53 AM
fbp_gizzer's Avatar
Default Car won't start up, PLEASE HELP!!!!!
Ok well i posted before about my car not wanting to start when you turn the ignition all the lights in the cluster light up but the motor won't turn.... after having acura look at it 3 times the finally said that it was a bad starter they replaced the starter and i picked up the car yesterday morning... i drove around the car all day and started it serveral times but again last night it did it again turn the key nothing. i woke up this morning before the tow truck got there and tried starting the car up and ofcourse it started right up... WTF? battery is fine and the alternator is fine puts out 70AMPS because acura tested them and the starter is brand new. what else is there.. could it be the ECU? i have a Apexi VAFC installed but i don't think that it would cause the car not to start.. please help i need it!!
Old Oct 3, 2002 | 06:53 AM
sic2kSi's Avatar
Default Re: Car won't start up, PLEASE HELP!!!!! (fbp_gizzer)
No telling, I have to prime my fuel pump for a few minutes before mine will start.
Old Oct 3, 2002 | 07:04 AM
shifthard's Avatar
Default Re: Car won't start up, PLEASE HELP!!!!! (juz1badLS)
get with the basic checks before you drive your self crazy like me when i had the same problem
check for any loose ground....
check your distributor cap rotor(if its evenly sparking in the rotor)
check if your wires are plugged al the way in(im sure you did that already)
check your spark plug gap
if you have an ignition coil(msd.crane,jacobs etc etc) chech their ignition coil
better yet put it back to a stock igniton set up(caused my stall)
hope this help
Old Oct 3, 2002 | 09:39 AM
PaChiLa Leader's Avatar
for real?
how you pump it?
ILUVTEC
Mar 20, 2010 01:31 PM
nighttrain33
10
Feb 25, 2007 08:10 PM
LilKrnThugBoi253
Aug 29, 2006 03:39 PM
HANABLE
Feb 27, 2005 05:40 PM
lowblazin
Nov 25, 2003 10:00 AM
