need help identifying this plug
Can anyone help me identify this plug? It is under the throttle body and comes off the harness just before the distributor plugs. The car has a z6 swap but it’s still obd0 the vtec is not hooked up purchased the car this way and I’m just trying to make sure everything is hooked up. Thanks
There are only 2 plugs like that on a OBD-0 car. The only one on the removable engine harness is the TPS plug. The other along the firewall is for the MAP sensor (originally located above the VIN number). The only problem is - the Z6 should have the MAP on the throttle body. The TPS wires will be GREEN, RED, YELLOW as the primary colors. (If I remember right the stripes are white, blue, white respectively...)
hotimportcrx
Jan 31, 2006 07:42 AM
