Starting Problem
Old Aug 7, 2011 | 08:36 PM
civicboy420's Avatar
Default Starting Problem
Hey guys, I just replaced the head on my 89 Civic, I have a brand new battery, plugs, and wires. I go to start and it doesn't even crank over. Usually when I go to start it, I hear the starter click when I turn the key to starting position (position |||), but I don't. It clicks loud from the starter when I go from position ||| to ||. I was told I have a loose ground somewhere but I connected everything back the way it was before I switched heads. I am stuck so I would greatly appreciate it if someone could help me out here, Thanks..
Old Aug 8, 2011 | 07:30 AM
B16-CRX's Avatar
Default Re: Starting Problem
Get a better ground wire that goes from the transmission to the body. I had the same exact problem and I used the same grounds when I did my swap.
zacatkings
Feb 28, 2011 08:41 PM
pooorman's type-r
Oct 7, 2008 03:07 PM
immrtaltchnq
Sep 22, 2008 05:36 PM
4potnick
Oct 9, 2006 03:38 PM
whatcivic
Dec 6, 2005 05:20 PM
