What vehicle did my ZC come from?
Old Aug 7, 2011 | 07:26 PM
zdelure's Avatar
Default What vehicle did my ZC come from?
Does anyone know what year make and model of vehicle a 88-89 ZC DOHC motor came out of?
Old Aug 7, 2011 | 07:42 PM
DJ_SaNdOz's Avatar
Default Re: What vehicle did my ZC come from?
They came in lower spec crx's and some lower model eg civics.
http://www.google.com/url?url=http:/...ed=0CEUQygQwAw
Old Aug 7, 2011 | 09:18 PM
JDpower's Avatar
Your lucky you got the rare ZC.
Old Aug 7, 2011 | 10:29 PM
tonylovesjdmEF9's Avatar
they came on the da3s crx efs and egs it all depends what year it is
Old Aug 8, 2011 | 04:32 AM
zdelure's Avatar
im lucky lol ill trade you. i cant get the ****ing thing running properly.
Old Aug 8, 2011 | 06:16 AM
jlicrx's Avatar
if your DOHC ZC has serial number (just below the "ZC" on the front of the block) starting with the number "2", it came only from the 88-91 JDM CRX Si model or 88-91 JDM Civic Si model
Old Aug 8, 2011 | 07:17 AM
thats pretty cool bruh i never knew that
Old Aug 8, 2011 | 07:33 AM
zdelure's Avatar
awsome. thanks alot guys
Old Aug 8, 2011 | 07:49 AM
but hey cool thing about the jdm zc dohc is torque numbers are great and hp is too problem is not alot of aftermarket parts so you gotta look into it and for say replacement parts for it just look for a 87-89 integra since they have the d16a1 (dohc zc)
Old Aug 8, 2011 | 08:07 AM
jlicrx's Avatar
the D16A1 is NOT a DOHC ZC - the 84-87 JDM DOHC ZC is very similar to the 86-87 D16A1, but not the same - the 88-89 D16A1 is only similar to the 88-89 D16A1, but not the same - the 88-91 JDM DOHC ZC shares a few parts (valve train, distributor, cylinder sensor, throttle body, pistons and rods) with the 88-89 D16A1 but is essentially a completely different engine - different head casting, different block, different crankshaft, different camshafts, different timing belt, different timing belt tensioner, different cam gears, different oil pump, different engine mounts, different intake manifold, different valve cover, different exhaust manifold, and more
91CivicEF
Jan 7, 2009 06:42 PM
fernruffryders
May 24, 2006 11:38 AM
notfastenough
Nov 5, 2003 01:21 PM
91_hatch_si
Apr 29, 2003 08:52 PM
muskrat
Jan 31, 2003 05:29 AM
