B18c5 partout!!! + type r wheels/seats
Old Aug 7, 2011 | 03:17 PM
TypeRMOBBiN209's Avatar
Default B18c5 partout!!! + type r wheels/seats
Im parting out my complete b18c5 fully rebuilt with oem parts. I got a slight rod knock at only 222 miles and i don't feel like fixing it so im parting it out. All prices are best offer. All the stuff came out of my itr. Stuff i didn't list prices for just ask so we can work something out because i dunno if it'll be sold as package deal or individually! If you want pics just ask.
PLZ BUMP IF VIEWED!
ALL PARTS FROM INTEGRA!! ALL PRICES OBO!!
(all the stuff has 222 miles)
-b18c5 block was hot tanked and bored .25 over
-type r crank
-type r rods with arp rod bolts
-oem jdm type r .25 over pistons with oem honda piston rings
-oem honda oil pump, water pump, timing belt
-all gakets and seals on block replaced and there oem honda
-all internals were all balanced
-arp head studs
-oem honda block fittings for catch can
-type r head was hot tanked
-brand new oem type r valve springs, retainers, and valves
-5 angle valve job
-type r injectors and fuel rail
-jdm itr pistos/rings/rods/arp rod bolt combo $250
-k20z3 oem honda clutch (about 5k miles) $120
-oem integra type r strut bar $100
-obd2b homemade tuck harness (needs some work missing a few plugs other than that works perfect) $30
-Progress 22mm cb7 accord sway bar never used $120
-10 pack of brand new arp washers for head studs $10
-homemade k20 tuck harness (missing injector clips) $250
-b18c5 block with whats left $OLD!
-itr head with valve train and cam caps $OLD!
-b18c5 itr stock intake pipe and box $OLD!
-k20 type r prc manifold $OLD!
-2.5" adjustable test pipe $OLD!
-oil catch can with oem honda block fittings $OLD!
-moroso oil pan $OLD!
-hasport motor mounts $OLD!
-rmf rep header $OLD!
-ati street dampner $OLD!
-jdm itr 16" white wheels $OLD!
-diy wrinkle red itr valve cover $OLD!
-mishimotor aluminum radiator $OLD!
-gates racing blue hoses $OLD!
-type r throttle cable $OLD!
-type r throttle body $OLD!
-type r intake manifold $OLD!
-usdm type r tranny $OLD!
-jdm itr tranny $OLD!
-OBD2 distributor $OLD!
-alternator $OLD!
-water pump $OLD!
-brand new ngk spark plug wires blue $OLD!
-aem cam gears 5 bolt black $OLD!
-exedy oe clutch $OLD!
-starter $OLD!
-f1 lightened 8 pound flywheel $OLD!
-oem axles and half shaft for integra $OLD!
-usdm front itr seats 9/10 $OLD!
-black vtec valve cover $OLD
-jdm f20b t2t4 5 speed lsd tanny..bought from engine distributor never used by me $OLD!
-itr shift linkage $OLD!
-Arp head studs b series studs/washers/nuts $OLD!
-type r fuel rail/ regulator/ injctors $OLD!
Old Aug 7, 2011 | 03:49 PM
sytfu_tommyR's Avatar
Default Re: B18c5 partout!!! + type r wheels/seats
bump!. nice stuff! how much would i be if i buy the oil pan,motor mounts,tuck harness,mishimotor aluminum radiator together?
Old Aug 7, 2011 | 03:51 PM
pArAdOxsqUArE's Avatar
view bump
Old Aug 7, 2011 | 04:52 PM
pm'd
Originally Posted by pArAdOxsqUArE
view bump
thanks
Old Aug 8, 2011 | 12:18 PM
bump i need this stuff sold
Old Aug 8, 2011 | 03:22 PM
crx_si-r's Avatar
how much for the head?
Old Aug 8, 2011 | 03:28 PM
pm me ..let me know exactly what you want with the head
Old Aug 8, 2011 | 07:48 PM
bump
Old Aug 8, 2011 | 09:44 PM
mytegisna's Avatar
New User
bump. would you sell the throttle body by itself? and the valve cover by itself?
Old Aug 8, 2011 | 10:18 PM
xsk8er406's Avatar
would the oil pan fit a b16?
Old Aug 9, 2011 | 12:04 AM
chithemc's Avatar
bump. beautiful engine
Old Aug 9, 2011 | 11:04 AM
Will pick up the motor mounts this weekend.
Old Aug 9, 2011 | 12:14 PM
i guess if no one wants it with the complete head...but the valve cover i will
i think it should
thank you sir
you just want the mounts now?
Old Aug 9, 2011 | 12:16 PM
all pm's replied ...if i didn't reply back then your inbox was full
Old Aug 9, 2011 | 03:52 PM
Yeah only have enough for mounts..
Old Aug 9, 2011 | 06:33 PM
killudie123's Avatar
how much would u sell the valve cover for?? and are the actual pistons damaged??
Old Aug 9, 2011 | 07:12 PM
xsk8er406's Avatar
whats the part number on the oil pan.... im interested in it
Old Aug 9, 2011 | 07:20 PM
RoTb TwEaK's Avatar
I want oil pan and harness send me a pik of the items mainly harness! Thanks 805-621-2438
Old Aug 10, 2011 | 09:49 AM
Rene1123's Avatar
pmed
Old Aug 10, 2011 | 12:46 PM
$30 for vc...no pistons are perfect
im not sure on the part number
lol my dog bit off like 2 plugs on the harness i don't know if you'd still be interested
Originally Posted by Rene1123
pmed
pm'd back
Old Aug 10, 2011 | 01:35 PM
mikecivic's Avatar
bump view
Old Aug 10, 2011 | 03:56 PM
very interested in the valve cover. location??
Old Aug 10, 2011 | 04:34 PM
RoTb TwEaK's Avatar
Send me piks to my fone!!
Old Aug 10, 2011 | 08:02 PM
161822's Avatar
Pm'd about cam gears and VC. Price on cams too please.
Old Aug 11, 2011 | 12:55 PM
im just swamped this week. im sorry if i didn't pm you or text back im just overwhelmed with text and pms. i will try to get back at everyone by the weekend
