Honda sport clutch??
Old Aug 7, 2011 | 12:30 AM
deathslaya62's Avatar
Default Honda sport clutch??
can you remove the centrifugal clutch and leave in the regular one and still run properly because i would like to do this, if you know how to plz tell me i have a trx250x 2011 and yes i can ride clutch
Old Aug 7, 2011 | 03:44 AM
slomofo's Avatar
GDD Member
Default Re: Honda sport clutch??
What do you mean by leaving in the "regular one" ? The TRX clutch is the same as any other motorcycle clutch which usually has like 1-4 bolts/springs, 5-6 clutch friction discs, and 4-5 plates sitting in a basket. That entire setup is the centrifugal clutch, what other clutch are you talking about that you plan on leaving in?
Old Aug 7, 2011 | 09:34 AM
on the new bikes there is 2 clutches not just the the old clutch where u can pop it in to 1st and not stall or move but i also have a clutch lever that allows me to use a regular clutch, it weird and i dont like it so i want to remove the centrifucal clutch and leave in the regular goto moto sport and look at the oem diagram of the 2011 trx250x clutch
Old Aug 7, 2011 | 10:56 PM
slomofo's Avatar
GDD Member
Then I'm lost then, sorry.
Old Sep 9, 2011 | 09:55 PM
anmolmark's Avatar
the sport clutch is a great idea. If she wants to ride using the auto clutch she can ignore the manual clutch altogether, all she will need to do is let off the throttle and shift. If at any point she decides she wants to learn how to use a manual it's there and feels just like a manual except it won't stall.
Old Sep 11, 2011 | 06:42 PM
Sliced Beard's Avatar
Look into a Rekluse Clutch
owner563818
Transmission & Drivetrain
Sep 5, 2016 01:08 AM
