alal9005 sylvania silverstar conversion?
just completed this,much brighter. good bang for the buck i bought them both for $27.00 out the door , homie hookups are great and now to the ?, is this safe or can the projecter or lenses be damaged because of the wattage,also what about fuses,can they pop. one more thing is the plug to the light fits .,but does not clip is this normal.any one who has done this your help will be appreciated . THANKS
That is cheap! Nothing will happen. The greatest danger is that the wires will melt but I doubt it. You will need to modifty the plug a bit to get it to fit.
sorry dont have a digital camera, this rig job is alot brighter than the piaa extreme series lights i had before. modified light with 1 extra o- ring and removed 2mm from center notch and cleared the two lines in the plug with a saudering gun. took only about 10 minutes, not bad and the wattage is 65 only 10 more watts than a standered 9006 bulb
omgwtfbbqcrx
Dec 10, 2006 04:50 PM
Iamhonda
Aug 22, 2003 09:18 PM
