*** 310 SoCal GARAGE SALE ***
***Updated 3-2-12***
Sup HT! I'm cleaning up my garage and I will be updating this so keep checking, you might need some of these parts! I am willing to ship just text me for shipping cost with your zip code.
Call/Text if you need more pics or info on anything: 310-756-2273
Parts that came off of my 92 Integra gsr:
B17A1 block (208,xxx miles) runs strong when pulled, but it does burn some oil - $400
rear mudflaps - $10
OEM corner lights - $10
Cruise control unit - $5
Ashtray - $5
Misc. parts:
ITR oem intake with K&N filter (Used it on my EG and I had to cut one of the bracket in the box) - $75
EG stock steering wheel - $40
90 CRX Si passenger seat with 89 HF bracket - $50
Omori boost gauge (45mm) - $80
Ebay catch can (black) complete BNIB - $25
2001 Integra GSR cams - $100 (low miles-great for turbo)
C's short shifter with MOMO **** (B series) - $75
OEM GSR 14mm complete rear sway bar - $30
Front upper strut ES bushings for DC/EG (new) - $10
D bracket w/ ES bushing for itr 22mm rear sway (new) - $10
Old school HKS turbo timer - $10
38mm Tial Wastegate spring (8.7 psi) - $5
89 CRX hf ecu (PM8) - $5
Lexus IS350 OEM front/rear brake pads - $40 (less than 10 miles!)
PICS:
Parts sold:
GSR Cluster - $150
MSD Distributor cap (p/n 8292) - $20
AC compressor, condenser, fan & bracket - $40
Brake master cylinder (mint) & booster - $20
T rear bracket - $20
B17 valvecover - $20
Steering assy with ignition & key - $10
Driver side fender - $5
Front Fork - $5 pair
distributor - $10
stock air box - $10
rear drum brakes - $10 pair
eg radiator - $10
OEM arm rest with bracket - $60
Authentic Nardi Classic 330mm steering wheel - $180
CRX "T" radiator support - $5
OBD2 alternator (99 si) - $40
PR3 B16 intake manifold - $10
alternator - $10
OBD0 B16 vtec solenoid - $10
DC/EG shift linkage - $20
JDM 1piece headlight rubber cover - $5 pair
DA Shift linkage - $30
PBR front/rear brake pads - $30
DA Front LCA - $5 pair
OBD1 vtec engine harness - $90
P30 intake manifold - $20
Intermediate half shaft - $20
SPC rear camber kit - $20
Complete set of lug nuts - $20
Old school HKS B-pipe for 88-91 civic -$20
SPC Front camber kit (DC/EG) - $30
Skunk2 tie bar - $65
Blox 4" velocity stack - $25
B16 cams - $20
GAB front strut bar (will fit EF too) - $100
USDM P30 obd1 ecu (virgin) - $250
AutoMeter shift light with pills - $60
Spark plug cover - $15 each
rear mudflaps - $10
Ashtray - $5
Misc. parts:
PICS:
Parts sold:
GSR Cluster - $150
distributor - $10
stock air box - $10
eg radiator - $10
alternator - $10
B16 cams - $20
