gsr b18c1 motor
Contact Info:
Dave
Fairmont W.V
on here
pm for phone #
obd-2 b18c1 usdm gsr motor runs good 149x in the motor.is all stock .
runs good can see run or will take video of it running
dose not come with intake manifold/thottle body/distributor/oil pan/ or exhaust manifold
$1200.
Dave
Fairmont W.V
on here
pm for phone #
$1200.
dcreech0 -
motor still runs good i have not did a compression test on the motor, the motor has never been taken apart , it is the way it come from honda all stock / DOSE NOT COME WITH INTAKE MANIFOLD ,DISTUBTER ,exhaust manifold ,FLY WHEEL . IT DOSE COME WITH OIL PAN THATS TAPPED FOR TURBO. i took it out of a 4 - door GSR with 149x on the speedo as for meeting you . where is half way im in fairmont w.v. if you would like i could do a compression test and give you the numbers .
purplepassiongsr - yes it's turboed right now on 8psi and i don't want to pull the motor apart it runs to good for that , you buy in for my asking price and then you can part it out if you would like but i will not .
yes thats what i said, go buy a gsr longblock that runs as good as this one for 1000 and then come talk to me till then gtfo bump
for EX. my brother just got a gsr swap from hmotorsonline.com with the clamed 35k on it and this motor runs way better when was in the 4 door gsr / 98 ex coupe stock for stock
