Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Front knuckle assembly SI vs DX
Old Aug 4, 2011 | 05:43 PM
underdog51's Avatar
Default Front knuckle assembly SI vs DX
Are the front knuckle assemblys the same for all the civics or is the SI different? Does anybody know (or can measure) the dimension from rotor face to rotor face where the wheels mount? I am building a tube frame car with KA24 and want to use the civic knuckles and axles as well. thanks
Scott
Old Aug 5, 2011 | 07:11 AM
bee guz's Avatar
Default Re: Front knuckle assembly SI vs DX
I don't know if this will help your cause, but I had an 06 Si and I used struts from the EX and LX.
The Si struts were built a little heaveyer but everything fit and worked right in the end.
Old Aug 5, 2011 | 07:59 AM
underdog51's Avatar
Thanks any info helps. My main concern is if the SI has a bigger or stronger wheel hub I want to use it. And if the wheel hub is stronger are the axle splines different or bigger?
Old Aug 7, 2011 | 07:27 AM
bee guz's Avatar
Try compareing bearing numbers should tell you if they are interchangeable, and the axle numbers should tell you if you are on the right track
Old Aug 8, 2011 | 11:02 AM
m_shake's Avatar
The knuckle, hub, and hub bearings between dx/lx/ex and si are all different, looks as it si stuff is larger(bearing and hub size)
Tippyman
May 19, 2014 07:29 PM
hamilton_civic
Mar 19, 2008 03:52 PM
schroeder
Feb 3, 2004 07:48 PM
riceboyEFsi
Feb 1, 2003 04:09 PM
crooked muffler
Jan 16, 2003 08:04 AM
