i need help please
Old Aug 4, 2011 | 10:46 AM
velocity66's Avatar
Default i need help please
hey i have a 1994 honda accord lx 5 speed, my dash lights went out the other and right after that my tail lights went out idk what the problem is. i know that it could be a fuse i found two blown fuses but how do i know that they are what cause it or that if i replace them that it is going to be fixed? the fuses that were blown were 7.5a which is just a back up radio fuse and the other one is 15a which is for a small light idk what this means or anything please help
Old Aug 4, 2011 | 10:55 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: i need help please
Guess what fuses directly relate to your problem.
Guess what fuses you should probably replace.
Old Aug 4, 2011 | 10:59 AM
velocity66's Avatar
what man?
Old Aug 4, 2011 | 11:07 AM
Both of those fuses directly relate to the issues you are having. Replace the fuses.
If you recently did a aftermarket radio install, I would look at that wiring to see if that caused a short causing them to blow.
*edit*
Small Lights Fuse - corner lights, taillights, dashboard lights, etc
Backup Radio - radio, antenna, etc
Old Aug 4, 2011 | 11:18 AM
velocity66's Avatar
alright thanks imma go do that now and see what happens
Old Aug 4, 2011 | 03:17 PM
velocity66's Avatar
thank you muffinman that was the problem its all fixed now
Lewspike69
Oct 21, 2020 08:55 AM
defensa24
Mar 8, 2011 06:45 AM
thisboyjulio
Nov 10, 2008 03:50 PM
team612thoon
Oct 26, 2006 04:34 PM
