97 Civic DX is having power loss problems
I have a 97 Honda civic DX. The car has 135k miles on it. When i put the AC/Heat on i lose power until i hit 2nd gear. The check engine light is not on and I have had the transmission and engine checked and there are no problems with either. I have done some research and everything i read say it could be the main relay or a short somewhere that is interfering with the fuel pump. But before i start ripping things out i would like to know if anyone has had this problem before and how they fixed it. As everyone knows trying to track down a short in the harness can be insanely time consuming. Any information anyone could provide would be greatly appreciated.
IACV adjusts air intake when the engine is under load (ie ac is on). Takes 5 minutes to clean it and it should probably be done anyway. idle speed and the iacv are two different things... your plugs are probably shot and causing a lack of power in the low end...
I thought 96 and on no IACV's
jestor21
Aug 4, 2011 05:12 AM
