Honda S2000 Honda S2000
Which head gasket to use?
Old Aug 3, 2011 | 10:56 PM
S2K Luver's Avatar
Default Which head gasket to use?
I used a Spoon Head gasket on my first S2000 held up just fine.
Car dynoed at 205/143 which isnt bad for an AP1 with only T1R and HG as mods.
Now I am doing maintenance to my AP1 which has 160,000 miles am changing a lot of things on it. Ordered all seals , gaskets but now comes time for the head gasket.
I saw one thats .014 anyone ever try anything this low it increases by .5 compression and the spoon one I had was .3 ?
Anyone can offer any insight? I ask on here because S2ki blows!
Old Aug 12, 2011 | 04:39 AM
HondaKyle's Avatar
Default Re: Which head gasket to use?
oem
Old Aug 12, 2011 | 05:56 PM
JUSTINTHECOASTI's Avatar
oem indeed
Old Aug 12, 2011 | 07:24 PM
Boots's Avatar
oem or nothing
Old Aug 13, 2011 | 08:36 PM
TOO MUCH TORQUE's Avatar
wait.....why are you changing it? O_O
Old Aug 13, 2011 | 08:50 PM
njn63's Avatar
...not sure if trolling.
OEM.
Old Aug 13, 2011 | 09:00 PM
dagle's Avatar
between the two choices, OEM... if you want to bump up compression, get aftermarket pistons.. shaving the head or using a thinner headgasket is a poor substitute IMO..
Old Aug 19, 2011 | 10:27 AM
Amuses2000's Avatar
spoon or oem, evans tuing has tuned dozens of car on them, no need to buy a $200 cometic
Old Aug 22, 2011 | 12:53 PM
ExVtec's Avatar
OEM, unless you are running a bigger bore, then cometic.
Old Aug 22, 2011 | 01:52 PM
bigmacnfries's Avatar
i think someone may have mentioned this, but i would go OEM
Joeski99Si
Apr 22, 2009 09:57 PM
HONDA RR
Apr 6, 2005 06:22 AM
rough_draft
May 5, 2004 12:53 AM
pinota
May 28, 2002 09:30 PM
