my 93 civic si
i have a 93 civic si with stock brakes and im wondering what honda/acura oem brake systems i can upgrade to?
i saw somewhere that i think someone put nsx calipers on his civic but i dont remember
ty in advance....
ty in advance....
what kind of engine do you have? if it is all stock you can just put aftermarket rotors and pads with sportier compound.it will be more than enough and cheeper.
The Si model came with rear disks right? So you can just put cross drilled rotors and upgrade the pads. Another good and useful upgrade is steel braided brake hoses.Make sure you purge the brake fluid.Dot 4 is preferable as it has higher boiling point.(unless the car is for track only ,then you can put the synthetic dot 5.1.
norurb
Northwest (Sales)
Jul 9, 2006 07:22 AM
