B20vEf9's Turbo EF Si Hatch Build
Old Aug 3, 2011 | 08:16 PM
B20vEf9's Avatar
Default B20vEf9's Turbo EF Si Hatch Build
Well some of you may have saw my coupe build thread. I had the coupe for over 2 years, and decided to do a build late 09 that was finished early last year. The car originally made 216whp with a 1.8L All Motor, and ended up picking up 16whp with e85 and cam adjustments.
Here's the build thread if anybody is interested.
https://honda-tech.com/forums/appearance-build-threads-122/b20vef9s-2010-cookie-cutter-lsvtec-build-thread-2723025/
Well I decided to trade the coupe to my friend for his Built Turbo B16 Ef Si Hatch.
B20vEf9's Avatar
Default Re: B20vEf9's Turbo EF Si Hatch Build
Engine:
B16 block
JE 9:1 Pistons
Eagle Rods
Oem Honda Bearings
ARP Head Studs
Block breather with z10 fittings
B16 Head
Supertech valvetrain
ITR Cams
Victor X
Edelbrock 65mm Tb
Precision 1000cc Injectors
STR Fuel Rail
3 Bar Map sensor
Hasport Engine Mounts
Thermal 3 inch exhaust
Transmission:
Ys1 Cable Case
ITR Internals
Gsr 3rd and 4th gear
Quaife LSD
Hasport Shift Linkage
Skunk2 Short Throw
Turbo setup:
Lovefab Ramhorn
Precision sc61
Full-Race Backdoor Fmic
Tial Wastegate
Tial Bov
3 inch down pipe
Aluminum hard piping done by IMW
JS MBC
Aeromotive FPR
Vacuum box
Suspension, Wheels, and Brakes:
Rota Grids
D2 1 pc coilovers
Function 7 Lcas
ASR Brace
Skunk 2 Camber Kit
Ebay traction Bar(Going to replace with ETD or Full-Race)
Blox Extended Lug Nuts
Interior:
Nrg Hub
Nrg Quick Release
Nrg Steering Wheel
Skunk 2 Shift ****
Aem Wideband
Autometer Boost and Oil gauge
Sparco Drivers Seat(For Sale soon)
C Pillar Bar
The car is converted to obd1 and tuned by John Kerr from IMW on Neptune. The car made 365whp and 240wtq on 93 octane
Old Aug 3, 2011 | 08:17 PM
B20vEf9's Avatar
Old Aug 3, 2011 | 09:05 PM
B20vEf9's Avatar
My plans are to have the car retuned on e85 and I'll be looking for over 400whp. I need to fix the oil drain setup, get a new traction bar, and sell that Sparco seat.
Old Aug 5, 2011 | 03:46 PM
B20vEf9's Avatar
Got the grids on
Old Aug 8, 2011 | 03:54 PM
B20vEf9's Avatar
Got the car on 20 psi today for the first time.
Old Aug 9, 2011 | 08:30 AM
vietdam89's Avatar
niceeee....
Old Aug 9, 2011 | 08:33 AM
chuwi_pty's Avatar
how is feeling????
track numbers??
Old Aug 9, 2011 | 09:15 AM
B20vEf9's Avatar
Good lol
No track numbers
Old Aug 9, 2011 | 10:30 AM
JdmHonda4Life's Avatar
sweet build man that is exactly wha i have in store for my ef when i pick it up i got the b20 allready on deck just need some $$$$
Old Aug 9, 2011 | 11:02 AM
dirtyharryhatch's Avatar
A Digital Frontier
Nice! what are you planning to make?
Old Aug 9, 2011 | 12:04 PM
B20vEf9's Avatar
The car made 365whp previously on 93
I want to make over 400whp on e85
Old Aug 10, 2011 | 05:05 PM
B20vEf9's Avatar
Well the car definitely needs a more efficient fan and a shroud setup.
This is the fan everyone recommends running.
http://www.the-fan-man.com/shop/size....html?cPath=33
I'll then have to spend $200 for a T1 shroud and $30 for the wiring kit, or have a shroud custom made by D-Rob which I'm not sure how much that'd cost.
or
I could order this fan which is 1 inch smaller and flows 350 less CFM, but I can get a shroud for it for $60. Not sure if this fan will require the special wiring kit with relay or not since it's 5 less amps.
It's basically the same other than being an inch smaller and flowing a little less, but it's still 2 inches bigger than my current fan and flows 810 cfm more, and I currently don't have a shroud.
Here's the shroud I'm looking at.
http://www.go-autoworks-store.com/goalrafansh.html
Old Aug 12, 2011 | 05:14 PM
B20vEf9's Avatar
Cut out the front bumper.
Old Aug 12, 2011 | 05:42 PM
egb18c5's Avatar
came out good
Old Aug 12, 2011 | 06:11 PM
4doorcivic16's Avatar
could you get a better pic off how the rear bumper is cut out? i always wanted to cut mine out like that
Old Aug 12, 2011 | 10:58 PM
B20vEf9's Avatar
Originally Posted by egb18c5
came out good
Word. It probably didn't do **** to help cooling, but I think it looks better.
Yea I'll get that tomorrow for you.
Old Aug 13, 2011 | 01:20 AM
eg714's Avatar
Very nice. Although i never own a ef i had always have love for them
Old Aug 15, 2011 | 06:11 AM
B20vEf9's Avatar
AS you can see it was just cut out. Not very good either I may touch it up with a dremel eventually.
Old Aug 17, 2011 | 10:56 AM
B20vEf9's Avatar
Just put the kill switch on since the battery is in the rear. I have to run the wiring still.
Old Aug 18, 2011 | 12:48 PM
B20vEf9's Avatar
Traded the Sparco for an EF Si Driver Seat.
Old Aug 18, 2011 | 05:25 PM
Aesthetic Gains's Avatar
Dos Pupusas
Turbo huh?
I tried turbocharging. It just wasn't for me.
Good luck with the build. Keep us updated
Old Aug 18, 2011 | 08:12 PM
B20vEf9's Avatar
I am liking it so far. lol
Old Aug 19, 2011 | 03:54 AM
egb18c5's Avatar
***** weak
Old Aug 19, 2011 | 04:13 AM
B20vEf9's Avatar
***** weak
