Clean EF hatch W/ LS motor swap
First of all, yes, it does have a hood and it matches the paint. I will include a Picture in the ad, its just a pain to re-install alone so.
1988 Honda Civic Hatch Clean Title in Hand 177k
1990 Ls swap
B16 Cable Trans
PR4 ecu
Si Lip
Si Cluster W/ tach
Si 3-spoke steering wheel
Polished Aluminum cam seal
Wrinkle Red Valve cover
Bronze C-pillar strut bar
Bronze Type R ****
All 4 OEM mudflaps
Aftermarket test pipe
Intake W/ Brand New filter
New Paint job (using Stock Paint Code)
Still has interior matched cargo cover (roughed up)
Matching Black seats from some kind of Integra all the way around, In good shape
Kenwood CD w/ Aftermarket speakers
15's w good tread little dirty, nice polished lip though
Lowered
Some sort of aftermarket clutch, kinda grabby
Fresh:
Valve cover gasket set
Aluminum cam seal
Axle seals
shift rod seal
Intake Filter
Plug wires
The swap itself is pretty Clean the motor has zero oil leaks, And stays clean. It is actually Fast surpisingly, and sounds very very clean. As for the engine bay, someone decided to paint it black? looks pretty decent though. The exterior paint job was done just a few months ago at a shop in eugene, receipt is in the glove box. All around clean car!!
541 971 9379 $2600 obo
no no no trades please I need to sell it quickly
Heres one with the hood installed
honda acura si gsr integra civic ef eg ek da dc crx del sol b18 b18 b20 b18a1 b18b1 b18c1 ef9 jdm hatch b16a
1990 Ls swap
B16 Cable Trans
PR4 ecu
Si Lip
Si Cluster W/ tach
Bronze Type R ****
All 4 OEM mudflaps
Lowered
Fresh:
Aluminum cam seal
Axle seals
shift rod seal
Intake Filter
Plug wires
nice.. i have an 90 SI that im swaping a 93 ls into and i should finish tmrw i wish my bay and interior was as clean as yours though.! haha
oh and IM SUPER JEALOUS OF YOUR TRUNK LID!!!!
dont lose that.!
dont lose that.!
im starting my b18b1 swap into my 90 civic si, i was told i have to get motor mounts from hasport. and someone told me i can use the stock ones out of my 91 integra that i got b18 from, im confused on which one is true, if you can help me out that would be much appreciated. this is my first honda swap.
JadeGreenEF9
Jan 29, 2006 10:07 PM
GorData
Aug 2, 2002 12:25 PM
