CV Shafts Causing Clutch Chatter?
Old Aug 3, 2011 | 06:04 PM
curtie94's Avatar
Default CV Shafts Causing Clutch Chatter?
Can a CV shaft really cause clutch chatter. When the car is cold only when taking off from first gear the car shakes horribly. Could it really be CV Shafts?
Old Aug 3, 2011 | 11:58 PM
holmesnmanny's Avatar
Default Re: CV Shafts Causing Clutch Chatter?
Not really. They're usually more of a problem when they get hot rather than when cold.
Old Aug 4, 2011 | 08:36 AM
hondamark35's Avatar
that sounds more like an engine issue/shudder. CV joints will cause vibration when the inner joint wears out or becomes pitted (as i've recently discovered..) but it's usually durring accelaration only (when the axles are loaded in the positive direction)
what shape is the engine in? when was it last serviced/tuned-up?
Old Aug 4, 2011 | 08:50 AM
curtie94's Avatar
It hasnt been tuned up in at least 5-6 years. The engine runs strong, I haven't had any problems with it ever.
The car only does this when I first start it in the morning, and it started this spring when it got out of the 20's F. The CV Shafts both need to be changed, but I havn't gotten around to it, thats why I ask.
The car is a 1991 Honda Accord 2-Door LX with 167,000 miles.
Only when accelerating from first gear, other gears seem to grab hard. After the car warms a bit and stops it shaking even first gear grabs hard.
Old Feb 28, 2012 | 05:06 PM
curtie94's Avatar
Sorry to bring back the dead, but I still havn't changed the joints and now it makes clunks on acceleration, is this the cv. It only does it when the car is cold.
Old Feb 28, 2012 | 08:25 PM
jdowen2's Avatar
Engine mounts?
Old Feb 29, 2012 | 01:26 PM
curtie94's Avatar
Im not sure because it also shudders under acceleration. I can be driving down the road accelerate and then the car shakes, this just started.
Old Feb 29, 2012 | 01:43 PM
Probably the mounts dude.
Old Feb 29, 2012 | 03:53 PM
curtie94's Avatar
Could the mounts also cause the chatter on take off? And how do i test the mounts. Because they all look good visually.
CarBug
Jun 9, 2016 02:58 PM
amath666
Sep 26, 2011 06:33 AM
david76008
Oct 10, 2008 08:34 AM
overtwo
Feb 21, 2008 10:05 AM
FULL-REV
Jun 30, 2005 04:24 AM
