B18c Type R Swap into a 2000 Civic Si
Old Aug 3, 2011 | 04:22 PM
SalisCzar's Avatar
Default B18c Type R Swap into a 2000 Civic Si
Hey guys i have a question, i just swapped in a B18c Type R into my Si. Everything is running Perfect. No Check Engine light, no Problems what so ever. The only thing im curious about is i just noticed that the Sensor that connects to the Intake manifold is not Connected. It seems to be the SENSOR ASSY., AIR TEMPERATURE. it seems like the sensor doesnt fit the socket??
Anybody run across this ...
Thanks
Old Aug 4, 2011 | 05:00 AM
kyden's Avatar
Default Re: B18c Type R Swap into a 2000 Civic Si
its normal when doing a swap. just run the one in your intake tube.
Old Aug 11, 2011 | 04:35 PM
zccr-xsi's Avatar
if the aior intake temp sensor isnt hooked up it should be throwing a code.just do what i did and sitck in the in intake tube.its a soft cel so vtec so should engage and it wont be in limp mode
siorhf
Honda CR-V & Element
May 3, 2011 06:40 AM
drastikchangez
Sep 8, 2006 12:33 PM
MAD SCIENTIST
May 10, 2003 05:50 AM
Qwikrex
22
Mar 31, 2003 09:38 PM
