p2p0 forged d16 rods for use with vitaras, brand new.
Old Aug 2, 2011 | 08:53 PM
OMG B16's Avatar
Default p2p0 forged d16 rods for use with vitaras, brand new.
SOLD
Old Aug 4, 2011 | 08:08 PM
OMG B16's Avatar
Default Re: p2p0 forged d16 rods for use with vitaras, brand new.
up
Old Aug 4, 2011 | 08:40 PM
CW-ITR's Avatar
Originally Posted by OMG B16
Item Description: Brand new p2p0 forged d16 rods custom length for use with vitaras, these are a little longer then eagles for higher compression.
Same as the FJT rods.
I thought Vitaras pistons are for forced induction. If that's right, why use these longer than normal rods to induce higher compression?
Old Aug 4, 2011 | 09:50 PM
OMG B16's Avatar
Since the vitaras are not made for the d16 motor the wrist pin location sits the piston into the cylinder bore slightly with standard length rods. The compression is in the 7's with standard rods and in the 8's depending on the motor set-up with the longer rods. You can get almost 9:1 with the right motor set-up with the these rods.
Also:
"Even though the setups have worked like this(using std length rods),
this is not completely ideal because the combustion is happening
not at the right place and there are compression ratios issues
(very low CR). So we have designed a custom I beam rod with a
custom length to solve this issue. Using this rod the Vitara piston
will sit right at deck height providing more Compression(one full point
on D16 engines) and making the combustion happen where it has to be."
If your wondering why high compression with turbo's then do some searching around.
Old Aug 7, 2011 | 02:00 AM
OMG B16's Avatar
BUMP
Old Aug 9, 2011 | 07:37 PM
OMG B16's Avatar
up
Old Aug 12, 2011 | 07:01 AM
OMG B16's Avatar
up
Old Aug 13, 2011 | 03:34 PM
OMG B16's Avatar
up
Old Aug 15, 2011 | 08:07 AM
OMG B16's Avatar
up
Old Aug 17, 2011 | 11:32 AM
OMG B16's Avatar
up
Old Aug 18, 2011 | 06:28 PM
OMG B16's Avatar
up
Old Aug 20, 2011 | 07:01 AM
OMG B16's Avatar
up
Old Aug 20, 2011 | 10:38 AM
Mr.Cheezil's Avatar
do you need to notch the block to use these rods?
Old Aug 20, 2011 | 09:45 PM
OMG B16's Avatar
Yes, but there sold. If your interested check out www.p2p0.com
4.8t
May 4, 2011 10:10 PM
iownahatchback
Jun 1, 2010 11:00 AM
iownahatchback
Jun 1, 2010 10:59 AM
swepper
11
Apr 22, 2009 01:56 PM
queez
Jun 24, 2003 06:43 PM
