93 CX w/ 99 D16Y8 Engine cuts out?
So i swapped a y8 into my 93 cx using the stock OBD1 engine harness, injecters, VX dizzy and a P28 ECU. I converted the 1 wire O2 to 4 wire O2, Ran my VTEC wires and other wiring i cant remember. (read the how-to writeup). I drove it for about 6 months with it slightly bogging below about 3000 RPM(never could figure out why?), Recently my radio started shuting off when i turned it up. When i used my turn signals the gauge cluster needles when all over the place. When i put it to the floor the engine boggs and cuts out. Now it wont even turn over. Ive tried a different ECU, Turn signal switch, Hazard switch, and a main relay, and still nothing. I checked all the grounds in the engine bay(even cleaned up the contact surface with some 320 grit sand paper, still nothing. Its progressively gotten worse up to this point. Im out of ideas. Any help with my delima would be great appreciated, thank you in advance.
jdm.I.am
16
Jan 7, 2011 02:41 PM
civicracer1993
Dec 25, 2003 08:04 AM
vladd
Nov 5, 2003 10:45 PM
