Coilover sleeves
Old Aug 2, 2011 | 07:37 PM
accordjuggalo1796's Avatar
Default Coilover sleeves
I'm looking at getting something to do an extreme drop on my car i'm trying to get atleast a 3" drop. I have been told that to do a drop like that the correct way would be to use tru coilovers. I was wanting to get coilover sleeves because theyre less expensive but i've heard they have a problem with rattling. Is this true and would i run into any other problems with coilover sleeves?
Old Aug 4, 2011 | 12:41 PM
TexasRedCD5's Avatar
Default Re: Coilover sleeves
Bump! I wanna hear the answer to this also.
Old Aug 4, 2011 | 01:50 PM
dglassmyer's Avatar
Here, this is an informative post that will answer all your questions
http://www.hondasociety.com/board/sh...d.php?t=109357
Old Aug 4, 2011 | 11:44 PM
361 accord's Avatar
dumping the **** out of the car like that is gonna be worse than stock
Old Aug 6, 2011 | 07:04 AM
halfkoreanboy's Avatar
If you do use coilover sleeves,only brand id use is ground control nothing else sleeve wise....and on another note if you do not have both side even you will have your sway bar fighting each side and will give you an even more tire wear and a uneven drop.....and slamming that low expect to buy shocks more often......and yes it will make a noise sooner or later unless you wrap the shock up in something to make it fit snug.........and sometimes (but not all cars) that have High Mileage,going that low can make ball joints and upper control arm go and if im not mistaken strains axles and you might get some clicking when turning after time but i could be wrong....and also tie rods will take a beating. But to be slammed its all worth it lol
Old Aug 6, 2011 | 07:06 AM
@ 361 accord like your location lol
kcari
Honda Civic (2001 - 2005)
10
Feb 12, 2008 05:04 AM
jewpont
Suspension & Brakes
Jan 28, 2008 05:58 PM
Regal
Suspension & Brakes
May 5, 2006 02:31 AM
justininhifi
Apr 30, 2003 12:25 AM
JDMTEG98
Jul 5, 2002 02:55 AM
