BBK Throttle body
TB's don't make much of a difference at all on D-series motors ( I assume that's what you're using it on, after reading your sig)
Also, keep in mind that the BBK 62mm throttle body has a larger opening than the intake manifold. You'll have to port out the IM where the TB bolts in, otherwise you'll see some extra material from the IM, restricting flow.
Does that make sense?
Its used, but looks like brand new still and yes i know i have to bore the IM.
Larger TB are no good on D-series?
hmmmmm.....lemme reread this thread again.
https://honda-tech.com/zerothread?id=261161
ImportAutoPerformance.com
Performance
141
Nov 13, 2008 08:45 AM
