FS.D,B,H JRSC,Turbo,Cams,Moving Sale!!!
Whats up Guys im Sure you seen me on here Before Well i Need to Clean All this stuff out of my Basement Because Moving Shop to New Location....So right now im only Doing Post Office Money Order...Since my Bank Account is Messed up But i will get a Paypal ASAP...IVE GOT A Voucher Thread ive been on H-T For Years Now....My name Zack Location Uniontown,PA 15478 Phone Number 724-984-6442
For Well Respected Member wit alot of Post i Will send First...Im just trying to make some extra Cash and Finish my build...So help me Out i will get alot more pics up soon Thanks Guys...
I Will have a List at Bottom of stuff that i need that i will trade for...This stuff is Priced to Sell
NOTE:DONT BE SCEARD TO ASK ME TO SEND U PICTURE OF ITEM WITH WHAT EVER YOU WANT ME TO WRITE&DATE TO VERIFEY I HAVE IT...or If u just need picture of sometime that doesnt have pic hit me up
1. DSM OBD1 390cc Injectors $70.00 Shipped or $80.00 Shipped/w Resistor Box
2.D16Z6 Cam Its got 2 Lines Threw it And Says E525...It has to Be atleast sTAGE 3 Because i put my Stage 2 Blox y8 Cam Next to It and these lobes was so Much bigger....$100.00 Shipped
D16Y7 Used 2k Miles GATE's Racing Timing Belt $45.00 Shipped
3.88-91 Civic NIB AIRTEX 190lph Fuel Pump...$45.00 Shipped
OBD1 D15b7 P06 Mt Ecu $60.00 Shipped
OBD1 D15y5 Vtec-E P07 MT Ecu...$50.00 Shipped/OBD2 P2E AT ECU $40.00 SHIPPED//D16Y7 OBD2 Mt Ecu $55.00 Shipped(Not pictured)
4.P-FAB Stainless Steel Turbo Manifold(SOHC D15,D16,D17)T3/38mm $200.00 Shipped
5.D16Y7 OBD2 Distributor...Blue Clear Cap...Perfect Working Order...52k Miles...$45.00 +Shipping
6.D16Z6 (92k)&D16Y8(61k)Starters $35.00 +Shipping Each
x2 D16Y8 OBD2 Altinators $50.00 Shipped Each....D16Z6 obd1 Altinator No pUlley $30.00 +Shipping
D16Y8 P/S Pump &P/S Bracket $50.00 Shipped
7.92-95 Civic MT Cluster No Tach $20.00+Shipping /96-98 MT Cluster No tach $25.00 +Shipping
8.GARRETT T3 Turbo ....IN.60/EX.48....Blown Oil Seals..Has Shaft Play $200.00 Shipped (One on Right)
BRAND NEW GARRETT TURBO....IN.60/EX 1.15/T4 Twin Scroll Flange..Im 98% Sure its Ball Bearing $700.00 Shipped
ill take Lost i got ina trade for my B16 Swap
9.SOHC Turbo Set up...WRX Turbo Not IHI its IN.50/.48....Its Welded to Sohc Manifold&Needs External Wastegate...2 1/4 Down Pipe/Flex Pipe &Stainless High Flow Cat DP is welded to turbo toDont ask lol...Turbo Has lil Shaft Play...
Will Cut DP Off For shipping $150.00 +Shipping
10.JACKSON RACING SUPER CHARGER...FOR SOHC....10k Miles..got off A buddy he took care of it...Has 10lb Pulley on it But May Need New Pulley...Does Need Belt To....Ive got the Altinator Bracket thing&Tensior(Not Pictured)....Oil Was Serviced 4 Times While Ran....Includes...JRSC Manifold/TB Neck/Charger/FMU/Y8 Fuel Rail/w Stock Regulator/w Bracket to Spin it/Tensiors/Brackets....Im Asking $750.00 OBO ...Will take Trades Such as Listed At bottom of List/Also open to other trades
11.D16Y8 BLOX Stage 1 Vtec Cam...Markings Say (P) R1...I researched and it says its BLOX Stage 1....$105.00 Shipped
12.ARP HEAD STUDS for D16Y7...Torqued Once...Only 1k Miles on them anyways...$75.00 Shipped Obo (Picture on Request)
13.BNIB BELKIN Wire For VGA/SVGA....I bought this at walmart for $22 bucks and got home seen it was wrong one...Never opened they wouldnt let me take it back ...$10.00 shipped
14.AUTOPIPE 12" Subwoofer 750 Watt...Duel Voice Coil...$50.00 +Shipping/Lighting Audio 2 Chl...750 Watt Amp $50.00 Shipped....Pioneer 6 Disc CD Changer $15.00 Shipped / HF Manifold Used for turbo Set up $25.00 +Shipping
15.x2 D16Z6 Fuel Rails $10.00 +Shipping Each...H22 FUEL RAIL $15.00 SHIPPED...AND SOHC Auto Z6 throttle Body $30.00 Shipped...D16Y8 FUEL RAIL $12.00 +sHIPPING No injectors
16.HASPORT Driver Mount...Used on H2D...Trimmed to fitt...Can even buy for the Inserts...$45.00 Shipped
17.SNOW BOARD...RETAIL $359.99 LIKE 5FT Mayb longer $85.00 +shipping
18.D16Z6 HEAD..Semi Bare..What u see is what u get....No valves..springs..retainers..vtec solenoid...valve cover...cam $45.00+Shipping
19.D16A6 PGMFI OBD0 Intake Manifold...Complete/w Injector Clips For Muti Port Swap $45.00 +Shipping
20.96-00 Civic Pillow Mounts for Frame...Perfect condition no ripps $30.00 shipped
21.Injector Resistor Boxs $22.00 Shipped Each...Good A/C Compressor $35.00 + Shipping/ EG Civic Sunroof,Dimmer,cRUISE Switch $10.00 Shipped...Crank Sensor From 99 GSR 58K Miles $20.00 Shipped/Cable VSS $25.00 SHIPPED/94 INTEGRA SUNROOF SWITCH $7.00 + SHIPPING/mAIN Relay $15.00 Shipped
What ever eles in Pic Make Offers
22.Vaccumm Gauge 0-30 Psi $12.00 Shipped
23.Honda Center Caps x5 $20.00 Shipped for 5....NEW Knock Sensor $45.00 Shipped/Holly Fuel pressure Regulator for Carb motors$20.00 shipped/97 GSR MAP Sensor/wPigtails $35.00 Shipped/D15B7 MAP SENSOR $15.00 SHIPPED
24.sohc upper&bottom Timing Covers $15.00 Shipped/OBD2 B-series Lower timing cover $15.00 +Shipping/x3 B-Series OBD1 Black Lower timing covers $12.00 Shipped Each
25.6" Filter / Aluminum Volcity Stack...Has Coupler on End of Volcity STack(Not Pictured) Fits right on 3" Intake or Turbo Inlet....$75.00 Shipped
26. 88 CRX SI 3pc OEM Taillights...Mint Condition...$65.00 +Shipping
27.EG Driver Side Mirrior $10.00 +Shipping /94 Integra 14" Hubcaps 2 are Silver/2 Black In mint condition tho $15.00 + Shipping /Civic Cruise Control Units $20.00 Shipped Each....OBD2 Engine Bay Fuse Box $15.00 Shipped/EG Civic Blower Motors $25.00+Shipping one in pic is chipped others are perfect//Whatever eles in pic is best offer
28.DRAG B-SERIES T3/38MM Turbo Manifold...Perfect Condition $100.00 Shipped.....Silver 38mm External Wastegate No Spring $45.00 Shipped
29.JDM SPORT FRONT MOUNT INTERCOOLER 28X6X2 $70.00 shipped
30.96-00 OEM Gauge Bazel $10.00 Shipped/94-01 Integra OEM Bazel $10.00 Shipped /EG Center Dash Cover Good SHape $15.00 Shipped
31.TimberLand Pro-Series (NOT GAB Knock Off's) Size 10 1/2....My uncle got me these for Xmas an they are to big on me.Steel Toe..These are Legit Boots..I wearn them Once....$80.00 Shipped
32.OEM Accord Coil...In working Order $25.00 Shipped
33.AEM TRU TIME Blue Adjustable Cam gear for SOHC $55.00 shipped
34.96 Integra GSR Black Passenger Side Airbag(MINT SHape Just dusty in pic...$55.00 Shipped
35.D16z/y Chromed Out/Shaved Valve Cover $70.00 Shipped
36.D16Z6 OBD1 Distributor...Works Perfect....$60.00 Shipped
37.95 Civic Ex P/S Rack Pinion...Complete&Works Perfect Just missing Tie rod...Only took off to swap for Manuel Rack $45.00+Shipping
38.92-00 Civic Fuel Pumps/w Mounting Brackets...All worked Perfect Just Swaped Out for Walboros At Shop $40.00 Shipped Each/w Bracket&Screen
Also EG Civic Rear View Mirror In the Mis $12.50 Shipped
39.Womens Harley DavidSon Riding Jacket...Size Small...This is a $180 Jacket...$50.00 Shipped
40.96-98 Civic Driver Side Headlight...Needs a Buff Job $22.00 +Shipping
92-95 Civic Cilmate Control Unit...Missing A/C Button Was no A/C IT was CX But used Block off for my Car :p $30.00 Shipped
41.Welding Helmet...Not auto Shade...But it has a Flap to Flap to flip up...Comes with other darker shades $30.00+Shipping
Cambell Heall or w/e Paint Gun Bottom feeed $20.00 Shipped
An Sand wheel air tool $20.00 Shipped
42.B18A/B STD Bore 81mm Nippon Pistons/Wrist Pins....No Rings...$90.00 Shipped SET OF 4 Just 2 in pic
43.P/S PUMPS/Clutch Pedals/Over flows Etc Make offers Need this GONE
44.Delsol dash Switchs Take all 3 for $15.00 Shipped...Integra Coupe Rear Whiper Motor&3rd Brake Light $35.00 Shipped
THINGS I NEED AND ILL WORK DEALS FOR
B18A/B EAGLE H-BEAM RODS/w ARp Bolts...No b.s bearings welded to it
B18A/B ARP Head Studs
B-SERIES Top Mount Manifold T3 Flange
Tial 38mm Wastegate
Crower Non-Vtec Turbo Cams
Omni Power 70mm TB
3 Bar Map sensor
CHECK OUT MY OTHER THREADS FOR WAY MORE STUFF
Tial 38mm Wastegate
Omni Power 70mm TB
3 Bar Map sensor
ViperRedCRX
Feb 20, 2002 04:03 PM
