Hesitations, hard start up ext..
So I go on leave, I live in FL. I heard while I was gone we had crazy rain...I get back, try to start the car and it gives me a hard time, initially i'm thinking that my car might've had water in the tank or bad gas from sitting there for two weeks. I put injector cleaner in the car and surprisingly it got better. Ran it a few days, then the same symptoms came back. So i'm kinda stuck as to what it might be. I had a few guys tell me they think it's the dizzy going bad because it's a common problem.....idk.
That's why i'm asking here, startup is kinda rough, through the rpms it hesitates, but then it randomly goes away and acts like nothing happened.
Car has a b16a2 btw..dunno if that helps..
I appreciate the responses.
Thank You
Thank You
Gasoline has a month long shelf life. It is possible it could have settled in the 2 weeks of not running it. Check RonJ@HT's signature, he has a link to a spark test that will answer your question about the distributor. How is it running now?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-how-test-spark-troubleshoot-spark-problems-2919450/ Here is a link.
right now it's running like crap...tried to start it up this morning and it popped like gunfire...happened last time like this when the tank got low : / dunno if that has anything to do w/it....a check engine light pops on here and there and then it'll disappear again.
alleyezonme
Sep 20, 2006 11:18 AM
peel17
Feb 9, 2006 09:06 AM
