93 accord intermittenly cranks then stalls.
Old Aug 1, 2011 | 03:54 PM
eshaktman's Avatar
Default 93 accord intermittenly cranks then stalls.
The car runs fine once it starts and holds. But, intermittently it will turn over and crank and then stall out. I can get a throttle reaction but only momentarily. I recently started having a shifter solenoid issue that may be related.
Old Aug 1, 2011 | 05:46 PM
Raf99's Avatar
Default Re: 93 accord intermittenly cranks then stalls.
I'm aware of the issue. Definitely a main relay issue. Some get a new one, others take the old out, re-solder the joints and put back in.
Google it, check it out.
Old Aug 1, 2011 | 08:01 PM
eshaktman's Avatar
Thank you so much. I will give it a try.
Old Aug 2, 2011 | 01:03 PM
eshaktman's Avatar
I tried the main relay (new) and i did not help. 1 more detail though- the engine will continue to run as long as I hold the key! And now the problem is continuous. Any further help would be greatly appreciated!
Old Aug 3, 2011 | 03:44 PM
poorman212's Avatar
Key switch.....see if you can return the relay for the key switch....as alway TEST things before replacing on a guess. Key to ON, is there power at the BLK/YEL wire at the dist?????
Main relay, I would have asked about the CEL coming on and going off when the key is in pos II.
For the key switch I would have asked which lights on the dash are on when the car dies.....but that is me.
In the link below there are different sections that would have helped in the testing to see what is wrong
http://techauto.awardspace.com/ignitionswitch.html
Dragon235
Sep 1, 2013 12:27 PM
boostedh22fag
Jan 18, 2013 12:30 AM
my93accord
Jul 16, 2010 07:27 AM
thegrobe
Sep 3, 2009 09:30 AM
beau93
Apr 19, 2007 03:10 AM
