PA 95 EJ D16z6 turbo 80,000 miles fs/ft $4900
Old Aug 1, 2011 | 01:58 PM
philly10psi's Avatar
Default 95 EJ D16z6 turbo 80,000 miles fs/ft $4900
Make: Honda
Model:Civic
Base: EX
Engine code: D16z6
Mileage:80,000 original miles on shell AND motor
Color:Black (used to be red)
GOODIES:
D16Z6 single cam
T3 turbo set up 10psi on street tune.
car is pushing around 200-220hp at the wheels depending on what octane fuel you use (i use 89 and up)
EMUSA 38mm wastegate
EMUSA blow off valve (sounds sexy)
Fujita 3" high performance air filter
fuel pressure regulator
15" motegi rims
BRAND NEW nitto neo gen tires
brand new jvc head unit
launch control (3500rpms)
cel shift light
internals have about 5000 miles on them at the most (valves, retainers, springs etc...)
new head gasket
new timing belt and cam gear
full 2.5" turbo exhaust set up
N1 muffler
high flow cat
stage 3 clutch (4000 miles on it)
7lb lightweight flywheel (4000 miles on it, revs VERY fast)
full suspension set up (handles like a go-kart)
tranny is nice and tight and in great condition no pop outs or grinds
projector headlights
altezza tail lights
550cc injectors
walbro fuel pump
has power steering but no ac. ( i have all the ac components...lines, condensor, fan, compressor)
car is black (used to be red)
nice interior. no cracks on dash. no panels missing.
prewired for subs
inspected LEGALLY till april 2012
NEVER TAKEN TO THE TRACK but its probably capable of running mid to high 13's on the right tires
EVERYTHING electrical works including moonroof AND cruise control.
BAD:
will need front brakes within the next 2 months or so
few scratches here and there (it is 16 years old)
trunk is gutted
car is going to the exhaust shop tomorrow. i'm putting on a new turbo manifold and downpipe. i'm also getting new hangers put on the exhaust and putting all new gaskets on manifold, exhaust and wastegate and getting everything tightened up.
ive been using this car as my daily driver for the last 3 months. i only drive 800-1000 miles a month...if that.
this car is FAST you get boost and vtec at the same time. after 4000rpms it takes off like a rocket. under 4k it drives like a normal civic and gets an average of 25mpgs. i can go almost 300 miles on a full tank. tank only holds 12 gallons. car does get 30mpgs on the highway. went to wildwood and back on a half tank
perfect sleeper and cheap insurance (i only pay $60 a month!)
I HAVE MORE PICS UPON REQUEST let me know if your interested. email me or hit me up 484-557-2676.
i'm asking $4900 or best offer. believe me i'm taking a loss. alot of time and money went into finishing this car. and i'm about to put another $500 into it tomorrow to get the manifold and exhaust updated. only reason why im getting rid of it is because i want something N/A
I will also consider trades for another civic (DOHC swap or SOHC VTEC only), accord, maxima, acura tl, integra ect... not in a rush to get rid of let me know what u have. the worst i can say is no
Miramax
Sep 16, 2015 01:26 AM
philly10psi
Jul 16, 2011 09:37 PM
civicflow
Oct 21, 2010 12:56 PM
civicflow
May 5, 2007 03:04 PM
turkdog
Aug 15, 2003 12:02 PM
