Transmission & Drivetrain Gearboxes, Differentials, Clutches
109.8mm ID Ring gear 4.4 ratio
Old Aug 1, 2011 | 12:08 PM
EJ1B18c's Avatar
Default 109.8mm ID Ring gear 4.4 ratio
a
Old Aug 2, 2011 | 02:22 PM
94EG8's Avatar
Seagull Management
Default Re: 109.8mm ID Ring gear 4.4 ratio
Originally Posted by EJ1B18c
I got sorted.
Turns out the most obvious solution was correct.
B16a 4.4 ring gear has identical tooth count and tooth angle to the B18c 4.4 ring gear.
They do, but they're still supposed to be a matched set, as in from the same transmission. Otherwise the gears may whine from different wear patterns.
gray_civic_coupe
Sep 16, 2005 01:15 PM
Jared
Mar 15, 2003 02:18 PM
