95 Accord JDM F22b Swap Questions
Old Aug 1, 2011 | 10:00 AM
4g4dcruisin's Avatar
Default 95 Accord JDM F22b Swap Questions
95, ex, stick.
Crank shaft was cracked on the old F22 so I got a JDM F22b and swapped it in. Everything was straight forward, fired right up, first try, drives/shifts no problem, but I have a couple of problems.
CEL, SRS are both on, tried ECU reset by removing 7.5 fuse in engine bay fuse panel, remains on.
I was reading about the SRS reset but I need some sort of plug for this? Not sure of how this works.
Also, when I'm on the freeway in 5th going about 60mph, I seem to start having problems picking up speed. I shouldn't, considering its a 2.2 and vtec. The old motor didn't have any problems accelerating at any speeds.
I have no leaks/smells/sounds coming from the engine, well a small rattling which is from the flex pipe at the header.
Oh, the o2 sensor on this car is stupid, it doesn't have a plug on the sensor side, so there are 4 prongs that go into the plug on the harness side, not sure if I have them in correctly.
Any help is appreciated. (I haven't checked CEL's yet)
Old Aug 1, 2011 | 12:40 PM
Default Re: 95 Accord JDM F22b Swap Questions
Really? No One?
Old Aug 3, 2011 | 08:02 AM
BUUUUUUMP
todd45
Feb 13, 2013 07:50 PM
4g4dcruisin
Aug 6, 2011 08:09 AM
okieflyr
Jan 27, 2009 03:30 PM
ph0on
Feb 18, 2007 05:29 PM
Jasno161
32
Feb 20, 2005 04:39 PM
