b20 smuttering
Old Aug 1, 2011 | 03:50 AM
crazyhondahead's Avatar
Default b20 smuttering
i have a jdm b20 running on p75 ecu...it kinda smutters during the idle..im wondering is it because i need to buy a adjustable fuel pressure regulator to adjust the fuel pressure. or is it sumthing else.
Old Aug 1, 2011 | 05:49 AM
turbodcxbro's Avatar
Default Re: b20 smuttering
You can get an AFPR and turn up the rail pressure a few psi but the real way to fix it is to have it tuned to get all the potential out of the B20. I just chipped the P75 in my Integra and tuned it on Crome, made so much difference in overall driveability and performance and well worth the time and effort. Crome is free and the chipping kit is $15 if you aren't afraid of soldering.
Old Aug 2, 2011 | 08:54 AM
thanks bro.sounds pretty good imm do it..but i got a obd2 ecu so i doubt it could b chipped
Old Aug 2, 2011 | 08:58 AM
but how many psi's do u think?
Old Aug 2, 2011 | 09:52 AM
OBDII chipping is a big negative... I'd start with around 50psi rail pressure.
Old Aug 2, 2011 | 10:05 AM
grumblemarc's Avatar
The Grumpiest
How do you know fuel pressure is what the real issue is? I'm not a swap guru but can someone confirm that is the correct ECU to run with that engine?
Old Aug 12, 2011 | 10:47 PM
a b18 ecu can run a b20 itll juss run lean like what mine is doin right now..once a bump up the fuel pressure it should runn better
JCushing
Jun 20, 2009 11:37 PM
Conclusive
Sep 13, 2007 12:53 PM
92integraVTECgsr
Jan 8, 2007 03:50 PM
BLUE EH3
Apr 6, 2005 05:39 PM
