Suspension & Brakes Theory, alignment, spring rates....
Ground control coilover springs
Old Aug 1, 2011 | 12:50 AM
AznBlueBoy's Avatar
Default Ground control coilover springs
I ordered a set of GC with 400F/450R
The springs come labeled 0800.250.400 which is supposed to be for the front and GC 200.64.77 which comes out to about 440lbs. Is there a reason they label the springs differently to tell which are for the front and rear?
I had them installed but the guy installed the 400lbs springs in the rear and 440lbs in the front.
The rear seems really high. I though these would lower the car .5" at the highest setting.
Is it because they were put on wrong?
Old Aug 1, 2011 | 03:37 PM
98civdx's Avatar
Master Detailer
Default Re: Ground control coilover springs
It doesn't always only lower the car.5''. it wil depend on the length of the springs as well.
if the rear is too high, that is such a easy fix it's stupid. lol
When the car is at a level ride height all adjusters will be on different heights.
Old Aug 2, 2011 | 02:48 AM
Libertariat's Avatar
Ek Forever y0!
Protip- Don't have someone else install your suspension.
Suspension is really easy to do, only time consuming. You really can't mess it up. Though i guess you can if a mechanic can do it wrong.
I suggest demanding a refund for the mechanic being a dipwad and doing it yourself at home. He must have the coil sleeve set on max height, which, on the top perch, could probably raise your car from the stock height.
Old Aug 2, 2011 | 08:13 AM
AznBlueBoy's Avatar
The reason I didn't do it myself at home is because I don't have a spring compressor.
Old Aug 2, 2011 | 09:56 AM
grumblemarc's Avatar
The Grumpiest
Adjust the rears.
Old Aug 2, 2011 | 10:22 AM
AznBlueBoy's Avatar
the springs are backwards though.
I wanted 400lbs front 450lbs rear.
Are the springs exactly the same except for the rate?
Old Aug 2, 2011 | 11:17 AM
The Grumpiest
Then swap them out. Jack up the car. Secure it with jack stands. In the front loosen or remove the 14mm pinch bolt on the fork then the remove the long 17mm bolt running through the bottom of the fork. Dial the coilover all the way down to make it easy to remove the whole assembly. At this point you can knock or slide the fork off. Remove the 2 14mm bolts on the strut tower. Slide out the shock assembly. The rears are much easier.
If two of the sleeves are shorter than the other then you'll have to remove the tophats and swap the springs and sleeves.
Install is the reverse of removal. Done. I can do a corner in 10 minutes or less.
When you see how easy it was you'll kick yourself for paying someone to do it. Next time see if you can rent a set of spring compressors from an auto parts store.
Old Aug 2, 2011 | 02:34 PM
98civdx's Avatar
Master Detailer
The 400lb's
are 8'' tall, 2.5 inch wide
The 450's Should 7'' 2.5'' wide
I could not find the exact spring on their site, so that is somewhat of a educated guess lol
But they are basicly the same. ones shorter, and lower spring rate.
The 400's in rear could explain the heigher height, due to the extra inch.
Old Aug 2, 2011 | 03:04 PM
90_EX_Civic's Avatar
he has the sleeves on already, don't need to take off the forks. op should only have to lower the collar and swap springs.
Old Aug 2, 2011 | 05:58 PM
The Grumpiest
Wrote that at work when I should have been working. Everything has to come off in order to swap the spring front to back so top hats have to come off anyway. If a pair of the springs are shorter then that would explain the ride height issue.
Old Aug 3, 2011 | 08:36 AM
AznBlueBoy's Avatar
The sleeves are on but they can still spin around when I turn it without loosening. Is this a bad install or is that how they are?
I know the no name brand coilover sleeves that came with the car had sleeves that did not move at all.
Old Aug 4, 2011 | 12:05 AM
SlayANT's Avatar
The collar is the piece that is tightened. Sleeves are free to rotate when the springs aren't compressed (ie when the car is jacked up and the suspension is hanging). Just remove the coilover assembly, take off the top hat, swap springs, reassemble, and reinstall. If the sleeves are different lengths, the longer set goes in the back.
200.64.77 is converts to: 7.87" (length) 2.52" (inner diameter) 430.18(lb/in). The springs are roughly the same height, so just swap them and adjust ride height to your liking.
Last edited by SlayANT; Aug 4, 2011 at 12:19 AM. Reason: metric -> standard conversion.
EcRzFinesT
Suspension & Brakes
24
Jan 21, 2011 02:25 PM
rekreb38
Suspension & Brakes
Nov 3, 2010 10:30 AM
Cass-anova
Oct 27, 2010 07:03 PM
randerson0248
Jun 29, 2008 02:26 PM
DarkBB4
Apr 8, 2006 03:19 PM
