85 CRX Carb/idle help
the car will start, usually will go up to 2k rpms then drop down till it stalls unless you press the gas, there is new spark plugs, wires, distributor cap, distributor rotor. we still have to try out cleaning it with a carb cleaner, but idk if the carb gasket isnt sealing, or if it is a vacuum line, i dont see any crack vacuum lines.
