Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2001 Honda Passport ignition problem
Old Jul 31, 2011 | 03:28 PM
Just a n00b's Avatar
Accident Prone
Default 2001 Honda Passport ignition problem
Hi, I don't know where this goes, but my friend has a 2001 V6 Passport AWD (automatic) that has a bit of an ignition problem.
Basically, the keys cannot be turned from the ACCESSORY to OFF position even if the gear selector is in PARK and the e-brake is pulled.
He says it has happened before, and the previous time he didn't drive the car for 2 days and on the 2nd day the key could be turned to OFF.
What could be causing this? Is there an quicker and surer fix than waiting 2 days?
Old Aug 2, 2011 | 11:13 AM
Accident Prone
Default Re: 2001 Honda Passport ignition problem
Bump. The key eventually came out, he says. But I'm leaving this up for a more permanent fix.
Old Aug 11, 2011 | 08:42 AM
NDNV's Avatar
Try a different key. Use a graphite lube. Perhaps a faulty ignition switch. Many Hondas had ignition switch issues and even recalls.
S33
Nov 17, 2014 11:43 AM
TooGz88
Jan 12, 2009 10:32 AM
Cabby89
Feb 23, 2006 09:22 PM
Digiti123
Jul 14, 2002 05:50 AM
