Transmission & Drivetrain Gearboxes, Differentials, Clutches
99 civic ex auto problems wont go in gear
Old Jul 31, 2011 | 11:41 AM
zacheryleatherw's Avatar
Default 99 civic ex auto problems wont go in gear
k so my stupid tranny stopped going into gear on my way home and no matter how many times I tried to restart it all it would do is rev up. The very next day i went out and it will go...it was jumpy but it moved. after a few times going back and fourth the same crap all it will do is rev and make a grinding/humming noise?
I believe that it could be the sylinoid's on the tranny cause it doesn't seem to be something wrong macanicly cause it wouldn't move at all.
Any help will be greatly appreciated, thanks in advance.
Old Aug 1, 2011 | 01:59 PM
Default Re: 99 civic ex auto problems wont go in gear
110 view's....yet nothing. I really don't want to buy a new transmission, or put it in the shop considering this one still drives! Knowing my luck it's something small and simple, I just have to find out what it is. I didn't get my check today so I couldn't try out the solenoids. hopefully tomorrow.
Old Aug 1, 2011 | 03:12 PM
94EG8's Avatar
Seagull Management
Dude, if it's grinding and humming, it's not the solenoids. When automatic transmissions fail it's very common for them to work for 10 minutes or so when the fluid is cold and then start slipping when they warm up. Nothing here suggests bad solenoids, even if they were bad depending on which one was bad you'd either have issues with the transmission not shifting properly (generally not shifting into a particular gear or being stuck in a certain gear. Or the torque converter wont lock up on the highyway in overdrive. But they absolutely will not cause it to do what it's doing. I'm not trying to be a dick, just trying to keep you from wasting money on things that aren't going to help you.
Old Aug 1, 2011 | 07:22 PM
thanks yeah i'm just gonna go to my local lkq and start pulling parts to change it to a 5 speed so far I have a clutch lol. The 93 del sol si tranny will work right being it is hydro and all? And I do need to change the intake manifold for the swap?
Old Aug 2, 2011 | 04:21 AM
94EG8's Avatar
Seagull Management
Yes and yes.
Old Aug 2, 2011 | 07:04 PM
cool I really liked that tranny when I had that car. How can I identify a si tranny, are there any codes on them somewhere that I can look for? I called my local lkq and they sell tranny's for 150.00, intake manifold's for like 30.00, the pedal assembly for about 30 or 40 bucks as well! Oh and the slave master cylinder with slave cylinder is only 15 bucks! I can't wait to go hunting for parts!
Old Aug 2, 2011 | 07:06 PM
Out of the three lkq's in the Houston area I shouldn't have any problems finding the parts too.
Old Aug 2, 2011 | 07:33 PM
94EG8's Avatar
Seagull Management
EX transmissions are stamped B000 around the passenger's side axle hole. (be careful because HXs are too) other transmissions are stamped A000.
Old Aug 4, 2011 | 09:40 AM
what about si transmissions?
Old Aug 4, 2011 | 10:35 AM
94EG8's Avatar
Seagull Management
Same thing as far as the '92 - '95 Si's went, B000 The '99 - '00 Si's had a B16 and use a B-series tranny. (unless you happen to be in Canada)
Old Aug 4, 2011 | 11:37 AM
thanks I really liked my del sol and how it did 90 in third and how fast it got it there. My 98 ex wasn't that quick.
Old Aug 9, 2011 | 05:41 AM
clutchdown_89's Avatar
tranny for 150 where u at mines leakin alot of oil i gotta 4speed 89 civic
SPOOLINmatt
Honda Civic (2001 - 2005)
May 24, 2017 01:26 AM
Justice Sky
Mar 10, 2017 03:31 PM
kidcolorado
Dec 1, 2014 06:15 PM
DrZaius
Apr 24, 2005 06:53 PM
Jaydeep
30
Jan 19, 2005 12:46 PM
