1989 CRX DX d15b obd1 won't start, please help
Old Jul 30, 2011 | 07:12 PM
1991crx16's Avatar
Default 1989 CRX DX d15b obd1 won't start, please help
So after changing the fuel filter, thinking that was the problem, and driving it fine with no problems for a couple of days, I go to leave work tonight and it won't start.. The fuel pump is on its own kill switch and when turned on you can here the fuel pump come on. Turn the key and it turns over ( meaning it cranks) but something is making a weird buzzing/clicking noise when you do this. This noise happens when the fuel pump switch is off as well. Does anyone have any ideas what it could be? The spark plugs are just about brand new, I was thinking maybe it is the distributor? if anyone has any input this would be great. Thanks! - Ben
Old Aug 2, 2011 | 08:05 PM
thekooler's Avatar
Default Re: 1989 CRX DX d15b obd1 won't start, please help
why is ur fuel pump on kill swtch if u did that because it wasnt work before its ur main relay up under dash driver side behind coin box that runs alot of stuff
Old Aug 2, 2011 | 08:42 PM
KINGVEM^^ED6's Avatar
check your grounds if your **** is buzzin that could be one of the problems
also pull out your main relay and check it may resolder the points they tend to get worn
Elgrys.Mendez
14
Aug 5, 2011 01:26 PM
clewis3
Mar 28, 2010 02:57 PM
rsanders21
Oct 30, 2007 10:22 PM
civic89si666
Mar 20, 2006 04:54 PM
mikeg015
Jul 9, 2004 07:43 PM
