1991 MR2 TURBO WHITE FOR SALE NJ!!!!!!
Listed for sale is a 1991 Toyota MR2 turbo with 121,000 miles on the odometer. It had been sitting for about 5 years partially disassembled due to the previous owner overheating the engine. It has been restored/upgraded by PR1ME with a lower mileage 88k 3SGTE. The car is loaded with ABS, PL, PW, leather, premium sound, COLD A/C etc. The car has manual steering and sunroof. It is an original turbo model. The car needs nothing and is ready to go.
EXTERIOR
The exterior of this car is straight and clean. The paint is in good condition and still glossy. However, It does have a few blemishes as expected on a 20 year old car. There is some paint staining and the bumpers have some imperfections.
INTERIOR
The interior is in awesome original shape. The leather seats have been recovered and are not torn. The headliner is in very good condition. The carpet is bright black and not sun-faded like the majority of MR2s for sale. The interior has an upgraded Kenwood in dash cd player.
MECHANICAL
The engine is a stock 3SGTE and non-LSD transmission. Everything is completely functional with zero issues. When I had the engine out, I replaced the
cam seals
front main seal
rear main seal
timing belt
water pump
hydraulic tensioner
Cut flywheel
OEM clutch
OEM slave cylinder
Hose from hell
Hose from hell on earth
air filter
exhaust manifold gasket
oxygen sensor
several o-rings and gaskets
OEM front brake rotors and rear rotors
All new brake pads
A/C compressor and line o-rings
Toyota Red coolant used
Synchromesh transmission fluid
Engine swap and all work was done by PR1ME in Dover NJ. www.PRIMENJ.net [/B]
SUSPENSION & BRAKES & WHEELS
The brakes are very good. They were completely torn apart and regreased all slides and brackets. New rotors and pads were used. Brake system has been flushed with all new fluid. The tires are starting to dry-rot and should be replaced.
My asking price for the car is $6,450 OR BEST OFFER. I have priced the car accordingly to what its value is. If you are looking for a cheap used and abused MR2 turbo, please look elsewhere. Finding low mileage examples of these cars are getting harder to find. I will hold onto it until the right buyer comes along. Please do not hesitate to ask me any questions. My shop can work with the buyer if they choose to have me install suspension, interior, or engine work.
[B]
phone: 973-214-0313
vin# JT2SW22M8M0004668
EXTERIOR
INTERIOR
MECHANICAL
cam seals
front main seal
rear main seal
timing belt
water pump
hydraulic tensioner
Cut flywheel
OEM clutch
OEM slave cylinder
Hose from hell
air filter
oxygen sensor
All new brake pads
[B]
phone: 973-214-0313
