Suspension & Brakes Theory, alignment, spring rates....
Bleeder screw won't bleed
Old Jul 30, 2011 | 09:36 AM
miamirice's Avatar
Default Bleeder screw won't bleed
So I am gravity bleeding my brakes. I am at the last bleeder screw and nothing will flow out of it. I loosened it to the point fluid started flowing out of the threaded part. So are there any tricks? I assume I have to quickly install a new bleeder screw. Any advice or tricks to minimize the mess?
Old Jul 30, 2011 | 09:48 AM
Drive 4 fun's Avatar
Default Re: Bleeder screw won't bleed
Remove it and clean out the port/hole, re-install. You can briefly cap the hole and slow the leak, even with wood dowel.
Old Aug 1, 2011 | 12:45 PM
miamirice's Avatar
on the wood dowel. Both fronts were very crudy. Both fronts had no caps on the bleeder. What a diff it made.
erikiksaz1
Suspension & Brakes
Jul 31, 2009 12:36 AM
beoy9
Jul 20, 2006 02:17 PM
vietxdragon
Mar 31, 2006 08:28 PM
ragejed
May 17, 2003 03:21 PM
extrmeboost
Apr 9, 2003 01:00 AM
