check engine light
Old Jul 30, 2011 | 08:23 AM
deltegra11's Avatar
Default check engine light
hows it going guys an gals Im in some need of some help here. I have a 95 Del Sol S the motor was swaped to a JDM B16A with a P30 ECU. I just got the body done on it an now for some reason have an engine light on an Im not sure why. I was trying to find how to check the engine light for about 30min an could not find a computer plug-in or a blink out.... but I do forget where to look for the blink out... and plus with this motor an ecu if i do find the blink out with the blink out even work???? please help!!!!
Old Jul 30, 2011 | 04:56 PM
civickiller's Avatar
Default Re: check engine light
you have to jump the blue connector under the dash above the ecu, it will flash the cel for the code
Old Jul 31, 2011 | 07:15 PM
fcm's Avatar
fcm
Old Fart
First question is, is the engine running with the CEL on?
If not, [will not start] can you hear the fuel pump priming when you turn the ign. switch on? 94
Old Dec 20, 2011 | 07:47 AM
deltegra11's Avatar
thank you for the info got it thanks!
dojo19xx
Honda S2000
Oct 21, 2011 10:46 AM
deltegra11
Jul 30, 2011 08:56 AM
CaliRockrr
Nov 26, 2005 04:37 PM
jeremy.
Aug 22, 2003 06:59 AM
johnzm
Sep 13, 2002 02:39 PM
