first gen teg swaps
yes i did do a search
allrighty, might be coming in to possesion of an 87 teg. i know, weak, but are swaps possible? d-series? can i get mounts for a b-series? any and all info on first gen teg hybrids (or just good advice other than get another car) is very welcoem
thanks
thanks
I sell the hasport mounts for the integra to Bseries motor:
585.00 for the mount kit
250.00 for the axle shafts.
this kit works well but you can't use the power steering. you canuse Ac but you have to mix and match ac lines between a 90-93 integra and 86-89 integra and you ahve to use the 90-91 integra ac comp. The car hauls but with just a B16a.
i had this swap in a 86 civic si(which is identical) and boy was it fun. If you can't afford this swap then you can use the ZC motor and go nos or mod a greddy turbo kit to work on the car. i persoally liked the ZC with NOS. lots cheaper and runs strong. good luck. and email me if interested in getting the parts.
