Transmission problem after F22B1 swap on 96 accord lx
Old Jul 29, 2011 | 09:03 PM
nandodeyknow's Avatar
Icon2 Transmission problem after F22B1 swap on 96 accord lx
I just swapped an obd1 f22b1 out of a 94 accord and put it into a 96 accord lx automatic. The motor runs strong and starts fine. The problem is when step on the gas to floor it, it climbs to 60mph and pauses until you let your foot off the gas and press back on it. Then it shifts to the next gear....
Are the sensors different from a 96 accord lx auto tranny and a 94 accord vtec tranny?
I really need help with this, thanks in advance :cry
Old Jul 30, 2011 | 07:04 AM
poorman212's Avatar
Default Re: Transmission problem after F22B1 swap on 96 accord lx
No codes, fluid is good, and the throttle control cable is properly adjusted?
Old Jul 30, 2011 | 08:39 AM
The fluid is good and cable is perfect, bow that I've done the swap the check engine light is on and flashing occasionally am I able to read the code still as obd2? If not how do I check the code?
Old Jul 30, 2011 | 08:56 AM
poorman212's Avatar
You left the ecu from the 96.......read them as such.
Old Jul 30, 2011 | 09:01 AM
The ECU is from a 94 accord vtec automatic POA-A51
Old Jul 31, 2011 | 05:45 AM
MAD_MIKE's Avatar
MM Gruppe B
Transmissions are the same between the 94-97s. No issues there.
If you swapped the harness and everything from the 94 into the 96 then you should be able to read the codes via the two wire blue connector.
Old Jul 31, 2011 | 07:52 AM
Do I have to use a jump wire? Not too familiar with obd1. I do know that there isn't a code reader for it
Old Aug 2, 2011 | 10:30 AM
Bump
Old Aug 2, 2011 | 01:43 PM
MAD_MIKE's Avatar
MM Gruppe B
Yes, you use a piece of wire(paperclip) to jump the two wire terminal, the CEL light should blink when you turn the car to ON, not start. Record blinks and look up code.
Old Aug 2, 2011 | 03:04 PM
holmesnmanny's Avatar
The ecu's use different connectors. How are you using an obd1 ecu in an obd2 car ? Are you using a subharness ?
96f22accord
Dec 17, 2014 05:00 AM
SAVIOVEGA
Oct 31, 2008 09:07 AM
profuse007
Sep 5, 2005 10:53 AM
deoexmacchina
Mar 17, 2005 09:35 AM
