clicking noise from LF during acceleration and braking
From a start initial torque on the wheel and when braking hard at slower speeds i notice a clicking sound from LF wheel. It will click 1-4 times whenever it occurs and it happens about 85% of the time when the above conditions are met. Im thinking it is my tie rod end... does this seem like a logical suspect for the noise? The only other thing i was thinking it could be is the sway bar end link or radius rod bushing.
Anyone experience this before, or know what it may be?
(92 prelude si)
(92 prelude si)
are they autozone/advance axles? for the whole summer so far i've swapped axle's every 2-3weeks. first time i was like "yea, ready for the event" then the clicking happened again during the event. need less to say went back and got another axle.
another thing is if it is a lifetime autozone/advance axle, it's free. it just takes a little time to swap out.
Found the problem
Got an alignment and figured i would put a new outer tie rod end on it, there was some play in it. This did not fix the problem... I went over every bolt in the suspension and everything was tight, except the rear bolt on the the radius rod, turned it another quarter turn or so and it solved the problem.
thanks for the help
thanks for the help
crispmofo
Dec 26, 2007 01:20 PM
97Alex
Aug 20, 2005 03:36 AM
lowRIDAH
12
Dec 27, 2004 09:05 AM
